airprint
Aggregator exe display issue
Mar 23, 2011 1:40 AM
I am using Captivate 5. I created an exe from Adobe aggregator with full screen option checked. The TOC does not display the topic text completely and part of the slides are not visible as the screen is not enough to display the entire slide. Do I need to change some display settings or aspect ratio so that the running slides are visible completely?
    Mar 23, 2011 11:14 AM   in reply to airprint
    Hi Airprint,
    Welcome to the community!  Would it be possible to post a screen shot so we can get a better idea of what you're seeing?
    Jim Leichliter
    Mar 23, 2011 11:42 PM   in reply to airprint
    Have you considered setting the TOC option to Overlay?  This would mean the users had to slide the TOC out when they wanted to jump to another topic or lesson, but it takes up a lot less real estate on screen.
    Why are you going for Full Screen mode?  This is usually only useful if you're trying to prevent or make it more difficult for users to exit out of the presentation.  Any resizing of Captivate captures also tends to deteriorate the crispness of on screen text.  So your captures will always look sharpest when displayed at exactly 100%.  Full screen percentage could be anything.
    Mar 24, 2011 4:12 AM   in reply to airprint
    This issue is fixed in CP5 patch. Can you please try installing patch for CP5 and then try it?
    Following are the suitable links for more details :
    http://kb2.adobe.com/cps/881/cpsid_88142.html
    http://blogs.adobe.com/captivate/2010/12/patch-for-adobe-captivate-5-i s-now-available.html
    Regards
    Chinmay Baid
