I am using Captivate 5. I created an exe from Adobe aggregator with full screen option checked. The TOC does not display the topic text completely and part of the slides are not visible as the screen is not enough to display the entire slide. Do I need to change some display settings or aspect ratio so that the running slides are visible completely?
Thanks Jim for your reply.
In the above screenshot the TOC is getting sliced on the left end and part of application slide on the right end. However when I save it in HTML format I can scroll vertically and sideways to view the complete screen because of the address bar and other menu bars which is not a problem. In the actual application I do not have to scroll anywhere and that's why I thought of creating the full screen exe. Please advise if changing some settings can resolve the issue. Also to close the application I have to press Alt+F4. Is there a simpler way?
Have you considered setting the TOC option to Overlay? This would mean the users had to slide the TOC out when they wanted to jump to another topic or lesson, but it takes up a lot less real estate on screen.
Why are you going for Full Screen mode? This is usually only useful if you're trying to prevent or make it more difficult for users to exit out of the presentation. Any resizing of Captivate captures also tends to deteriorate the crispness of on screen text. So your captures will always look sharpest when displayed at exactly 100%. Full screen percentage could be anything.
Actually this TOC has been created in Aggregator Project and here I do not find the Overlay option that is there in normal project. I have created seperate swf files which I am combining in Aggregator and as we add each swf file the TOC is generated automatically. I have tried publishing without the fullscreen option and still the issue remains
This issue is fixed in CP5 patch. Can you please try installing patch for CP5 and then try it?
Following are the suitable links for more details :
http://kb2.adobe.com/cps/881/cpsid_88142.html
http://blogs.adobe.com/captivate/2010/12/patch-for-adobe-captivate-5-i s-now-available.html
Regards
Chinmay Baid
