Suchys
Handling menu items in menu created by CSXSInterface.instance.setPanelMenu
Mar 28, 2011 2:36 PM
Folks,
If I create menu using CSXSInterface.instance.setPanelMenu, such as new XML(<Menu><MenuItem Id="Item_1" Label="Item 1"/></Menu>) - (I removed some quotations intentionally), is there a way to enable/disable menu items on fly? I tried to add attribute enabled="false" but this does not look it has any effect.
Any idea appreciated.
--Petr
    Mar 28, 2011 2:42 PM   in reply to Suchys
    Nope.
    Harbs
    Mar 28, 2011 2:51 PM   in reply to Suchys
    I'm not sure what you mean by "go native". CS SDK panel flyout menus do not support enabling/disabling. You can work around it by changing the contents of the flyout menu on the fly...
    HTH,
    Harbs
    Mar 28, 2011 3:15 PM   in reply to Suchys
    Yes. Native panels can enable and disable menu items. It's a CSXS panel limitation...
    Harbs
    Jan 12, 2012 12:54 AM   in reply to Harbs.
    Is there another way to create flyout menu without using CSXS?
