Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Installing LC on Weblogic - where to start?
Avatar
Former Community Member
Hello!
Please,  a newbie in trouble here!
I have installed LC several times using the Turnkey installer and using JBoss, MySQL, etc.
Now I have to install it on Weblogic - where do I start?
Should I run the same installer I would use for JBoss?
Or is there another file I should run?
Please, help!
Marcos
1 Accepted Solution
Avatar
Correct answer by
Level 7
You need to download a separate install binary - you cannot use the JBoss install binary for WebLogic.
Please go through the following documents first:
- Preparing to Install Guide (single server) : http://help.adobe.com/en_US/livecycle/9.0/prepareinstallsingle.pdf
or
- Preparing to Install Guide (cluster) :http://help.adobe.com/en_US/livecycle/9.0/prepareinstallcluster.pdf
and
- WebLogic Install Guide : http://help.adobe.com/en_US/livecycle/9.0/install_weblogic.pdf
The LiveCycle Product Blog also will help:
http://blogs.adobe.com/livecycle/
Good luck.
Avatar
Correct answer by
Level 7
or
and
Good luck.
Avatar
Thank you!
I've found the download page and seen the files are over 2 GB.
Does the file include Weblogic or will it install on an environment where Weblogic should already be installed?
Marcos
Avatar
Level 7
The file does not include WebLogic.  Adobe expects WEbLogic to be already installed and configured.  The same applies to the database also.
