I've either hit a mental block or have become temporarily blind, but I cannot find "Convert to Profile" in Illustrator 10.0.3 Mac, running Tiger 10.4.11.
Any hint or slap on the head that might jog my memory will be appreciated. The Help files have not been helpful yet. As the fortune cookie said, old age always comes at a most inopportune time. ![]()
Thanks in advance.
rcraighead wrote:
Do you mean "Type>Create Outlines"?
Good grief, no! I'm not quite that senile yet! ![]()
I'm referring to Converting a document's color profile to a different one, and that's different from Assign Profile. My working color profile is ProPhotoRGB (to be the same as my working color space in Photoshop CS4) so when I open an sRGB document, I want to Convert to ProPhoto RGB. Convert, not Assign.
Thank you.
____________
Wo Tai Lao Le
我太老了
steve fairbairn wrote:
Or do you mean Assign Current Working Space (colour profile) when opening a file?
No! When you Assign a profile, you preserve the numbers but you change (wreck the hell out of) the colors. When you Convert to a Profile, you change the numbers but you preserve the colors.
It seems that old AI 10 did not have such a menu Command in the Edit menu, as Photoshop has, so the workaround would be to close the file and pen it again, at which time you do get presented with the choice of CONVERTING to a profile.
Edit:
Edit > Color Settings (Cmd+Shift+K)
No, Changing your Color settings is a global dialog box that affects your working space, not your open document.
Thank you for your time anyway.
Jacob Bugge wrote:
(Too) Long time no see, Tai Lao.
And what Steve said.
Sorry, but no.
If your working space is ProPhoto RGB, and you have been working on a ProPhoto RGB file, you save it, and you want to save a copy as an sRGB file, how are your global Color Settings going to help you CONVERT the existing file to sRGB (say, for web)?
AFAIK, Illustrator never had Convert to Profile.
I'm not sure how documentation suggests to achieve that if there is any suggestion at all but what I do is duplicate the file, delete everything, then Edit > Assign Profile, and finally copy everything from the original and paste in place with preserving layers to the new document. This is equivalent to Convert to Profile.
