AVIsar*
Is there a way to: Export images from DICOM media into Illustrator?
Mar 31, 2011 2:23 PM
I am trying to find a way to automatically import sets of images from DICOM media (Digital Imaging and Communications in Medicine) into Illustrator. To be more specific I need to load up about 20 heart-slice images from DICOM CDs or any other type of archival systems into Illustrator.
These MRI DICOM clips show slices of the heart pulsating in systole (when the heart is the smallest ) and diastole (when the heart is largest) and phases in-between (systole and diastole are two time phases of the heart cycle, represented by time numbers), at various topographical locations (these would represented by slice numbers, or space numbers).  I would like to be able to input the number of the slices (space numbers) in systole and diastole (time numbers) and then with the push of a button to import the respective jpeg images into Illustrator.
This thread is related to a previous one “Is there a way to calculate the area of a shape?”
I would greatly appreciate the help.
Avi
    Community Member
    Mar 31, 2011 3:57 PM
    Maybe you can script it.
    Community Member
    Mar 31, 2011 4:55 PM
    placing (importing) images is definitely scriptable
    Community Member
    Apr 1, 2011 2:33 AM
    You may also be able to live trace them to get the path area calculations… PS extended has some additional features that may be helpful in this kind of work too…
    Community Member
    Apr 11, 2011 11:53 AM
    Hi George, I can give it a try. I sent you a message, please check.
    Community Member
    Apr 11, 2011 4:08 PM
    George, on top of the page next to "Welcome, AVIsar", click on the button "Your Stuff", then "Private Messages" to check your messages, I sent you a message earlier.
    Community Member
    Apr 11, 2011 4:44 PM
    try this using the Bridge and alt (option) key select the images and then go to Tools-Illustrator-Live Trace andsee if it works for you.
    Community Member
    Apr 12, 2011 1:01 AM
    Yes there has been an option since CS2 for this… If I recall correctly the script only allows 10 pics to be processed but its a simple quit edit and re-launch to change that… Where you may need some time is setting up a specific tracing option… getting the right threshold etc.
    Community Member
    Apr 12, 2011 9:25 AM
    I found a sample file on the net, couldn't Live Trace it straight from Bridge. Opening it in PS and exporting to JPEG is straight forward, that might be all the OP needs, since he mentioned in a previous thread loading images was tedious, he might be doing something different. You're right Mark, getting the right settings that yield satisfactory results is the hard part. Need to try with actual data...
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
