Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Mar 31, 2011 4:29 AM
Some background: I making a plugin that consists of some photoshop scripts and a panel created in Adobe Configurator. Basically the panel has some buttons which executes some functions in the script. The plugin is described in greater detail and can be downloaded here http://lumens.se/tychpanel
The problem: To reproduce the problem, do the following:
  • Give the panel focus by clicking somewhere on it.
  • Switch to another application, then back to Photoshop. Keyboard focus is lost.
Any ideas why this happens, and what to do about it?
Note: this is somewhat of a cross-post started at http://www.ps-scripts.com/bb/viewtopic.php?f=2&t=4021&sid=d3c3d77dd128 984f8ee30252f0f4cf2a however, as I think it's more of a Configurator / Panel issue rather than a scripting issue I'm now asking here as well.
    Mar 31, 2011 5:43 AM   in reply to Reimund T
    All seems ok on my mac osx system( 10.6.6).
    or maybe I misunderstand the problem
    Mar 31, 2011 8:27 AM   in reply to Reimund T
    The steps I tried are:
    1) click on your panel
    2) switch to illustrator
    3) switch back to photoshop
    4) Open  the dialog window by keyboard pressing Shift+Cmn+S
    I can type the filename and I can   dismiss the save as dialog windows  Esc Key without any problem
    I tried also other way and other Keys without any problem
    If that are the right setps to test the problem, iI can say that all is ok with me
    If so try to repair permission on your drive and then to refresh Photoshop preference file
    ( opening Photoshop   pressing   at the same time   Cmnd+ Opt+Shift )
    Mar 31, 2011 9:16 AM   in reply to Reimund T
    To repair permission on mac os x:
    close all your opened applications open disk utility select on the left column your hard drive and then on the right  in the bottom click on " repair disk permission " close when it finish
    Not so sure but the problem you have seems  to be quite the same kind that  happened to someone trying to switch among  tools through the  keyboard with   some  panels
    Mar 31, 2011 10:51 AM   in reply to Reimund T
    As I suspected.
    there are some thread  here about keyboard issue
    at the moment I don't  remember which one but Im pretty sure there was a solution in some cases
    try to take a look.
    If  I find  something that can  help you to solve the problem on your computer  I will be glad to inform you
    Compliment for your panel ,next days I will try it deeper
    Mar 31, 2011 12:34 PM   in reply to Reimund T
    many and different problems around photoshop keyboard,
    also when a panel is not involved, as you can see here
    http://forums.adobe.com/message/3437082
    Have you updated to the latest osx version?
    if not try 10.6.7 that could  solve some problem  with the  keyboard
    http://blogs.adobe.com/jnack/2011/03/mac-10-6-7-fixes-photoshop-cs5-co nflicts.html
    other suggestions could be :
    - duplicate the default photoshop keyboard and create a new workspace
    or
    - try  creating a new user account and  test there
    Mar 31, 2011 2:15 PM   in reply to Reimund T
    so sorry for you
    ms  cromaline :-)
    Mar 31, 2011 7:21 PM   in reply to Reimund T
    I'll have someone investigate. Sounds like an issue with the HTML widget. The Esc key should return the focus from the panel - always.
