How to get Repeater's runtime height
Apr 1, 2011 4:01 AM
I have a Repeater that may contain several 'Text' UI components at runtime.
Now I need the total height occupied by these collective text UI elements.
Please let me know how to do it.
Amey
    Apr 1, 2011 12:24 PM   in reply to Ameya Mogare
    if your code is somewhat like this:
    <some mxml container id="my_container">
         <mx:Repeater>
              <mx:Text/>
         </mx:Repeater>
    </some mxml container>
    in an event handler write something like this:
         var repeaterTotalHeight:Number;
         for each (var component:UIComponent in my_container.getChilderen()) {
              repeaterTotalHeight += component.height;
    Hope this helps.
    T.K.
    Apr 5, 2011 3:22 AM   in reply to Ameya Mogare
    maybe try skillGroupsVBOX.getChildren() instead of your skillGroupsVBOX.getChilderen() and add import mx.core.UIComponent; in your script?
    Apr 6, 2011 2:41 AM   in reply to Ameya Mogare
              <mx:VBox id="skillGroupsVBOX" horizontalAlign="left" verticalGap="0">
                    <mx:Repeater id="rptSkillGroups" dataProvider="{SkillGroups}">
                        <mx:Text text="{rptSkillGroups.currentItem.sgname}"
                                       click="clickHandler(event.currentTarget.getRepeaterItem());"
                                       mouseOver="clickHandler(event.currentTarget.getRepeaterItem());"
                                       buttonMode="true" useHandCursor="true"
                    </mx:Repeater>
                </mx:VBox>
    If you change
    by
         click="clickHandler(event.currentTarget);"
    Then you will get the Text object and can access the .text property in your
         private function clickHandler(item:Object):void {
              item.text;
    to get the index in the VBox, just to this with the same code as above :
         skillGroupsVBOX.getChildIndex(item as DisplayObject); // item must be the Text object return by event.currentTarget
    Hope this is understandable :]
    Apr 6, 2011 6:46 AM   in reply to Ameya Mogare
    you've got something like that :
                        <mx:LinkButton label="somelabel"
                    </mx:Repeater>
    and you want to get the label of the LinkButton?
    In the actionscript :
              item.label;
    I think I don't understand what you want, sorry.
    Apr 7, 2011 1:01 AM   in reply to Ameya Mogare
    you tell me if that works
