Is there a way to set up meta data in LiveCycle that will map over to Adobe? In the adobe properties there is a "Keyword" section. Where can get enter the Keywords in LiveCycle to that they will map over to that keyword section in Adobe?
Jodi
the keywords can be definded manuall in the XML source.
Look for the following segment ...
<rdf:Description xmlns:pdf="http://ns.adobe.com/pdf/1.3/" rdf:about="">
<pdf:Producer>Adobe LiveCycle Designer ES 9.0</pdf:Producer>
</rdf:Description>
In the xml you want to add this:
<dc:subject>
<rdf:Bag>
<rdf:li>Keywords</rdf:li>
<rdf:li>keyword 2</rdf:li>
<rdf:li>keyword 3</rdf:li>
</rdf:Bag>
</dc:subject>
The meta data in XML is located at the bottom. Locate the following and add the script.
<rdf:Description xmlns:xmp="http://ns.adobe.com/xap/1.0/" rdf:about="">
<xmp:CreatorTool>Adobe LiveCycle Designer ES 8.2</xmp:CreatorTool>
<xmp:ModifyDate>2011-04-04T13:15:27-05:00</xmp:ModifyDate>
<xmp:CreateDate>2006-03-24T12:09:19-05:00</xmp:CreateDate>
<xmp:MetadataDate>2011-04-04T18:17:18Z</xmp:MetadataDate>
</rdf:Description>
<rdf:Description xmlns:xmpMM="http://ns.adobe.com/xap/1.0/mm/" rdf:about="">
<xmpMM:DocumentID>uuid:2b8434e9-051b-4cd4-946d-4a430813611d</xmpMM:Do cumentID>
<xmpMM:InstanceID>uuid:f38d5eb5-91f9-4597-83de-d564cb55505a</xmpMM:In stanceID>
</rdf:Description>
<rdf:Description xmlns:dc="http://purl.org/dc/elements/1.1/" rdf:about="">
<dc:format>application/pdf</dc:format>
<dc:subject>
<rdf:Bag>
</rdf:Bag>
</dc:subject>
Ida Eve.Tracy
radzmar,
Your approach worked great, but is there a way to add values to the keyword tags automatically (via Javascript) by retrieving such values from user input (field data)?
Example:
Name.rawValue = John
State.rawValue = FL
Results:
"John" and "FL" both shows up as a keywords in Properities.
Shaun
you won't be able to change that values at runtime as the matadata is not part of the form template itself but contained in the PDF.
http://partners.adobe.com/public/developer/en/xml/xfa_spec_3_3.pdf#pag e=1252
At design time you could use Designer's macro capabilities to create new metadata without entering the XML source.
But there is currently no such macro that can do this, so it needs to be developed by someone.
