Metadata in LiveCycle
Apr 4, 2011 10:01 AM
Is there a way to set up meta data in LiveCycle that will map over to Adobe?  In the adobe properties there is a "Keyword" section.  Where can get enter the Keywords in LiveCycle to that they will map over to that keyword section in Adobe?
Jodi
    Apr 4, 2011 10:33 AM   in reply to Jodi1725
    Click on File --> Form Properties
    Add meta data to the Info tab.  Anything entered here will carry over to Adobe.
    Apr 4, 2011 10:43 AM   in reply to Jodi1725
    You might have to code it in the xml code along with the encoding.  I am testing your issue now on one of the forms I am currently working on and will let you know what I find out.
    Eve Tracy
    KDA/ IRT
    (785) 368-6261
    Eve.Tracy@kda.ks.gov
    Apr 4, 2011 11:18 AM   in reply to Jodi1725
    the keywords can be definded manuall in the XML source.
    Look for the following segment ...
    <rdf:Description xmlns:pdf="http://ns.adobe.com/pdf/1.3/" rdf:about="">
             <pdf:Producer>Adobe LiveCycle Designer ES 9.0</pdf:Producer>
    </rdf:Description>
    ... and insert a tag with your keywords, so it looks like.
             <pdf:Keywords>keyword1, keyword2, keyword3,keyword4</pdf:Keywords>
    </rdf:Description>
    Apr 4, 2011 11:22 AM   in reply to Jodi1725
    In the xml you want to add this:
    <dc:subject>
                <rdf:Bag>
                  <rdf:li>Keywords</rdf:li>
                  <rdf:li>keyword 2</rdf:li>
                  <rdf:li>keyword 3</rdf:li>
                </rdf:Bag>
    </dc:subject>
    The meta data in XML is located at the bottom.  Locate the following and add the script.
    <rdf:Description xmlns:xmp="http://ns.adobe.com/xap/1.0/" rdf:about="">
            <xmp:CreatorTool>Adobe LiveCycle Designer ES 8.2</xmp:CreatorTool>
            <xmp:ModifyDate>2011-04-04T13:15:27-05:00</xmp:ModifyDate>
            <xmp:CreateDate>2006-03-24T12:09:19-05:00</xmp:CreateDate>
            <xmp:MetadataDate>2011-04-04T18:17:18Z</xmp:MetadataDate>
          </rdf:Description>
          <rdf:Description xmlns:xmpMM="http://ns.adobe.com/xap/1.0/mm/" rdf:about="">
            <xmpMM:DocumentID>uuid:2b8434e9-051b-4cd4-946d-4a430813611d</xmpMM:Do cumentID>
            <xmpMM:InstanceID>uuid:f38d5eb5-91f9-4597-83de-d564cb55505a</xmpMM:In stanceID>
          </rdf:Description>
          <rdf:Description xmlns:dc="http://purl.org/dc/elements/1.1/" rdf:about="">
            <dc:format>application/pdf</dc:format>
            <dc:subject>
                <rdf:Bag>
                </rdf:Bag>
            </dc:subject>
    Ida Eve.Tracy
    Apr 4, 2011 11:25 AM   in reply to Jodi1725
    Next to your Design View tab, there should be XML Source tab.  If not, right click on the space next to the Design tab and select XML.
    Apr 4, 2011 11:33 AM   in reply to Jodi1725
    No problem, let me know how it works out.
    Eve Tracy
    Apr 4, 2011 1:13 PM   in reply to Jodi1725
    Wonderful, good to hear!
    Eve Tracy
    Aug 10, 2012 3:10 PM   in reply to radzmar
    radzmar,
    Your approach worked great, but is there a way to add values to the keyword tags automatically (via Javascript) by retrieving such values from user input (field data)?
    Example:
    Name.rawValue = John
    State.rawValue = FL
    Results:
    "John"  and "FL" both shows up as a keywords in Properities.
    Shaun
    Aug 13, 2012 12:06 AM   in reply to SI_MSD7
    you won't be able to change that values at runtime as the matadata is not part of the form template itself but contained in the PDF.
    http://partners.adobe.com/public/developer/en/xml/xfa_spec_3_3.pdf#pag e=1252
    At design time you could use Designer's macro capabilities to create new metadata without entering the XML source.
    But there is currently no such macro that can do this, so it needs to be developed by someone.
