TrackDaddy
OS Crash when rendering project
Apr 8, 2011 9:44 AM
When I am rendering a project the OS crashes.  It's not a blue screen.  It actually just disappears.  Then entire machine just shuts off.
The event viewer shows Event ID 41 (see event information below).  This is event it s new to the log.
Repro Steps:
- Copy any MTS file from my camera to the desktop (Canon VIXIA HF R21)
- add it to the timeline
- Render the file (render to youtube or locally as an avi)
- The render never completes.  It crashes.  The machine just turns off.  (I was trying to use PRE to create a DV-AVI to edit)
- It seems to fail at a specific step in the process.  Just not sure there is a log someplace for the render.
Additional info.
If I play any MTS file in the time line it flows nicely for about 20-30 seconds.  then the video gets jumpy.
I understand the minimum system requiremetns for HD editing is 4GB Ram.  I see that I have 2GB.
Question?
Is this a problem that I could fix by throwing money at? (obviously that answer is usually yes, but I mean simply adding memory)  I would hate to buy an additional 2-4 GB's of RAM only to find out that was not the problem.
It really feels like a step in the process is writing outside a buffer.  The OS just shuts down at that point.  It's not a reboot.  It just shuts off.  I have to manually restart the machine.
System Info
Hard Drive
WD6400AAKS SATA 3 Gb/s,  7200rpm, 16 MB Cache, 640 GB
System Information
Time of this report: 4/7/2011, 20:12:00
Machine name: IDK
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850) (fully patched via Windows Update)
Language: English (Regional Setting: English)
System Manufacturer: HP-Pavilion
System Model: AW011AV-ABA p6250t
BIOS: BIOS Date: 05/06/09 11:31:10 Ver: 5.39
Processor: Intel(R) Core(TM)2 Quad CPU    Q8300  @ 2.50GHz (4 CPUs), ~2.5GHz
Available OS Memory: 2048MB RAM
Page File: 1413MB used, 2680MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
Display Devices
Card name: ATI Radeon HD 4300/4500 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x954F)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_954F&SUBSYS_16131462&REV_00
Display Memory: 1274 MB
Dedicated Memory: 506 MB
Shared Memory: 767 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: HP 2159 Series Wide LCD Monitor
Monitor Model: HP 2159
Monitor Id: HWP282B
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll ,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1070 (English)
Driver Version: 8.831.2.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 3/8/2011 21:55:52, 795136 bytes
Event Info
System
-Provider
[ Name]Microsoft-Windows-Kernel-Power
[ Guid]{331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID41
Version2
Level1
Task63
Opcode0
Keywords0x8000000000000002
John ...
    Apr 8, 2011 9:56 AM   in reply to TrackDaddy
    AVCHD requires a quad-core CPU - such as an Intel i7 930 - to **effectively** edit - you have a quad, but I'm not familiar with the model
    Video editing requires at least 2 hard drives to **effectively** edit
    Only 2Gig of ram, with Win7 64bit, leaves VERY LITTLE for video editing... you are stressing your computer past what it may handle
    I use Premiere Pro... but as a general idea...
    My CS5/AVCHD 1st Impressions http://forums.adobe.com/thread/652694?tstart=0 includes a link to the computer I built... since the GTX 285 is no longer sold, I would now go with a GTX 460 or whatever is the current "best bang for the buck" - AND I would buy 4Gig-by-3Sticks memory to be able to expand from 12Gig to 24Gig if needed
    For my home hobbyist, family movies (which means that I am not trying to recreate Star Wars with video effects or many layers) AVCHD editing is "as smooth as spreading warm butter on hot toast" (also the MP4 video from wife's Flip camera)
    My 3 hard drives are configured as... (WD = Western Digital)
    1 - 320G WD Win7 64bit Pro and all programs
    2 - 320G WD Win7 swap file and video projects
    3 - 1T WD all video files... read and write
    Apr 8, 2011 10:07 AM   in reply to TrackDaddy
    Along with John T's comments, also see this ARTICLE.
    Also, you state that the system restarts, but you do not see a BSOD. Actually, there might be a BSOD, but if you have the OS set to Reboot on Errors, you just might not be seeing it. I would reset the OS to NOT Reboot on Errors, so if there is a BSOD, you will be able to see what is happening, though a BSOD screen can be cryptic to the point of absurdity.
    Also see the link on BSOD issues.
    How much defragmented, free space do you have on your single, physical HDD? That is often a big issue.
    Good luck,
    Hunt
    Apr 8, 2011 10:22 AM   in reply to TrackDaddy
    John,
    A Quad-core should be adequate to edit AVCHD material, though the speed, smoothness and joy might be greatly improved with a newer CPU, such as a an i7-9xx model.
    The RAM will be a major limitation, especially with Win7-64-bit, which will use that, just to run itself, leaving very little for the programs.
    If one has a large enough Page File (and especially if it's on a fast, separate physical HDD, some of that limitation can possibly be overcome. I would definitely look into establishing a static Page File, as that will take a load off of the OS, trying to dynamically manage the Page File size.
    Good luck,
    Hunt
    Apr 8, 2011 6:52 PM   in reply to TrackDaddy
    John,
    Transcoding will tax a system, and probably as much as almost any other operation.
    With a BSOD, heat issues are the # 1 cause, though not the only one.
    Hope that the new heatsink will solve the issues. In that article, to which I linked, there is another link to tools. SpeedFan is one of those. Within reason, one's computer cannot run too cool. That is why I always use the largest, most efficient case available, then add every fan possible, plus heatsinks on everything.
    Good luck,
    Hunt
    Apr 9, 2011 8:00 AM   in reply to TrackDaddy
    I have NONE-ZERO-NO idea what CPU cooler will actually work with your CPU and HP motherboard, so don't rush out and buy this one, but this is what I bought when I built my computer last year
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103057
    This one is not as tall as a lot of after market coolers, and cools very well
    You will have to find out what brand/model will work with your CPU and HP motherboard
    I will say you should get a new/better CPU cooler BEFORE you do any more video work... so you don't kill your CPU
    Apr 9, 2011 8:21 AM   in reply to John T Smith
    For a CPU cooler, I just pipe the air from my wine cellar (55F) into the case, right over the CPU... Now, I do notice that most of my footage has a Merlot sort of cast...
    Like John T., I added super-cooler onto the CPU (size and clearance had to be calculated carefully), and then ducted one additional fan through the case to it, plus similar for the video card. I never miss a chance to add a fan to a case, and as newer, more efficient (and ofthen quieter) models of fans become available, I upgrade mine.
    Good luck,
    Hunt
    Apr 11, 2011 8:29 AM   in reply to TrackDaddy
    John,
    The GPU, so long as it's an nVidia, or ATI/AMD, with good driver support is not that important. As you have found, PrE does not rely that heavily on the GPU, though it does interface very intensively with the driver.
    Wish that we had a crystal ball, as the only considerations on GPU choice would be:
    1. Will Adobe incorporate any aspect of the Mercury Playback Engine (MPE) into PrE, like they have with PrPro CS5 and CS5.5?
    2. Will one ever be moving up to PrPro?
    My guess is that for # 1, the answer is, not any time soon, but only the user can address # 2.
    For some background on MPE, see this ARTICLE.
    For some tips on buying, or building a computer for editing video, see this ARTICLE.
    Good luck,
    Hunt
    Apr 11, 2011 9:06 AM   in reply to TrackDaddy
    Go to http://forums.adobe.com/community/premiere/hardware_forum
    Once there, start with the FAQ DROP DOWN LIST at the top
