FlexPMD View not displaying results Eclipse 3.6
Feb 27, 2011 9:59 AM
Below are the relevant software installations. FlexPMD is configured as defined in the documentation.
When running FlexPMD, it appears to be churning away, however, there are no results that appear in the FlexPMD View window. Is this an issue only with Eclipse 3.6???
** Software versions ***
FlexPMD 1.0.0.v200912091712
flex-pmd-all-in-one-bundle-1.2
Eclipse 3.6
FlashBuilder 4.0.1
*** Eclipse Log File Entries ***
!ENTRY org.eclipse.ui 2 0 2011-02-27 10:49:20.167
!MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2011-02-27 10:49:20.167
!MESSAGE Cannot bind to an undefined command: plug-in='com.adobe.ac.pmd.eclipse', id='com.adobe.ac.pmd.eclipse.flexpmd.runCommand.category'
!ENTRY org.eclipse.ui 4 4 2011-02-27 10:49:20.707
!MESSAGE Unable to create menu item "com.adobe.ac.pmd.eclipse.toolbar.runCommand", command "com.adobe.ac.pmd.eclipse.flexpmd.runCommand.category" not defined
    Feb 28, 2011 3:20 AM   in reply to TucsonJava
    Can you try uninstalling the version you have and try installing from this temp update site? http://www.rialvalue.com/flexPmd/updateSite/ This is a version to be released
    Feb 28, 2011 8:21 AM   in reply to TucsonJava
    Any chance you are running on Windows 7?
    It looks like it is actually not related to Eclipse 3.6:
    http://www.javaprogrammingforums.com/file-i-o-other-i-o-streams/5230-f ile-c
    reatetempfile-throws-exception-win7.html
    Can you try to run this command line:
    Java -Xmx256m -jar
    C:/eclipse/configuration/org.eclipse.osgi/bundles/874/1/.cp/flexPmdRun
    time/flex-pmd-command-line-1.1.jar -s
    C:\workspace\BlissClient\src\com\othenos\bliss\business\DocumentDelega te.as
    -o .
    If this is the case, we will see what we can do.
    Cheers,
    Xavier
    Mar 14, 2011 12:49 PM   in reply to TucsonJava
    I am also having a problem w/ FlexPMD not displaying any results in eclipse.  I am on Windows XP however. I am using FlashBuilder standalone Burrito I6. I tried adding a flag to point to a temp directory, using one that existed on my machine, but that didn't change anything.  PMD had been working on this machine w/ previous FlashBuilder versions.  CPD still works.  I've tried Versions 1.1 and 1.2 with identical results.
    Mar 29, 2011 1:35 PM   in reply to TucsonJava
    I also have the same issue with it not being able to make the temp. file. I moved my temp folders around, still won't work. I'm using eclipse 3.4.1 w/ Flexbuilder 3. Any ideas?
    Mar 30, 2011 1:37 AM   in reply to cnojima2
    please can you unsintall your current FlexPMD eclipse plugin and install this yet-not-released version http://www.rialvalue.com/flexPmd/updateSite
    This new version should fix this problem for you along with several improvements.
    Xavi
    Mar 30, 2011 6:08 AM   in reply to Xavi Beumala
    I think the file you posted is corrupt.  I put it in the dropins folder but eclipse hasn't added flex PMD to preferences.  The file is only 1..2 K in size which seems way too small.
    Mar 30, 2011 6:27 AM   in reply to TucsonJava
    Thanks for the update. Sadly this still isn't working. I uninstalled and updated using the site you posted. I get this same stack trace
    java.io.FileNotFoundException: C:\cnojima1\temp\4\flexpmd2731671333939586734dir\pmd.xml (The system cannot find the file specified)
    at java.io.FileInputStream.open(Native Method)
    at java.io.FileInputStream.<init>(FileInputStream.java:106)
    at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMDResultsParser.parse(FlexP MDResultsParser.java:112)
    at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD.processResultsFile(FlexP MD.java:180)
    at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD.process(FlexPMD.java:68)
    at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD.process(FlexPMD.java:1)
    at com.adobe.ac.pmd.eclipse.flexpmd.actions.RunFlexPMDJob.run(RunFlexPMD Job.java:83)
    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
    I can run the commandline version (1.2) fine. This is a Windows Server 2003 sp2 x64 box. Let me know if there's any other info I can give you to debug.
    thanks,
    -c
    Mar 30, 2011 6:39 AM   in reply to jerela
    @jerela use it as an update site not as a file to in the dropins folder
    Mar 30, 2011 6:41 AM   in reply to cnojima2
    Hi cnojima2,
    can you open the errors log view in eclipse and check the messages in there?
    Also there should be an entry printing the command line executed. Could you try to execute it directly from cmd and see what happens?
    Mar 30, 2011 7:11 AM   in reply to Xavi Beumala
    Yup, this works totally fine. I just transformed the [java -Xmx256m -jar ...etc]
    into the raw
    and it worked fine.
    So 3 things happen in the event log:
    1) the command runs
    2) i get a warnings:
    null
    Info
    Wed Mar 30 19:09:59 PKT 2011
    Mar 30, 2011 10:09:59 AM com.adobe.ac.pmd.engines.AbstractFlexPmdEngine <init>WARNING: Access is denied at java.io.WinNTFileSystem.createFileExclusively(Native Method)
    java.io.File.checkAndCreate(Unknown Source)
    java.io.File.createTempFile(Unknown Source)
    3) I get an error
    null
    Error
    Error running FlexPMDC:\VENDEV~1\cnojima1\temp\4\flexpmd6740339094822211326dir\pmd. xml (The system cannot find the file specified)
    java.io.FileNotFoundException: C:\VENDEV~1\cnojima1\temp\4\flexpmd6740339094822211326dir\pmd.xml (The system cannot find the file specified)
    The directory is created successfully, but it's completely empty (no pmd.xml file exists)
    Mar 30, 2011 10:45 AM   in reply to Xavi Beumala
    Ok I got it installed but get and error when I run pmd or cpd.
    java.lang.NoClassFoundError:  java -Xmx256m -Djava/io/tmpdir=C:/temp
    Could not find the main class
    since it still new where my custom ruleset was it may have some of the config  left from the old version.
    The java arguments are set to  java -Xmx256m -Djava/io/tmpdir=C:/temp
    which seems to be what the error is complaining about.
    Apr 4, 2011 1:50 AM   in reply to cnojima2
    @cenojima2 are you on win7? Can you try relaunching Eclipse as admin (right click on Eclipse > Run as administrator) and see if it works
    Apr 4, 2011 1:52 AM   in reply to jerela
    @jerela I'm not sure what exact problem are you having. You can reset your configuration from Eclipse > Preferences > FlexPMD
    Apr 4, 2011 8:02 AM   in reply to Xavi Beumala
    The problem was what to reset it to.  I was able to install on a different machine and figured out that "java" shouldn't be one of the java arguments .
    That fixed it.
    Apr 8, 2011 7:39 AM   in reply to Xavi Beumala
    I'm on a Windows Server 2003 x64 sp2 box. I can't run as admin on this box actually so i can't test but the folder is created correctly (so i have rights) but the file isn't there. Running the command line works fine also.
    Apr 12, 2011 5:57 AM   in reply to Xavi Beumala
    My eclipse is 3.5.1 and it runs on windows7. I have the same problem. But running flexbuilder as administrator makes the problem go away.
    But I don't like having to startup 'as administrator', so please is there another workaround?
