qdjch
TypeError: Error #1009:     Help me?
Apr 12, 2011 10:23 PM
When I new instance of classm, error under
TypeError: Error #1009: TypeError: Error # 1009: can not access a null object reference property or method.
at course/course1()
//instance class
var myCourse:course = new course();
myCourse.course1("Chapter01-1/Session01/config/Config.xml");
//class
package
import fl.transitions.*;
import fl.transitions.easing.*;
import fl.video.*;
import flash.events.*;
import flash.display.*;
import flash.net.*;
import flash.text.*;
public class course extends MovieClip
  private var xmlPath:String ;
  public var loader:URLLoader;
  public var loadppt:Loader;
  public var urlppt:URLRequest;
  public var xmlData:XML;
  public var tween:Tween;
  public var display:MovieClip;
  public var playpausebtn:MovieClip;
  public var mutebtn:MovieClip;
  public var volbar:MovieClip;
  public var seekbar:MovieClip;
  public var ttime:TextField;
public function course1(val:String):void
   xmlPath=val ;
   loader.addEventListener (Event.COMPLETE, onDataHandler);
   loader.load (new URLRequest(xmlPath));
   display.playPauseButton = playpausebtn;
   display.muteButton = mutebtn;
   display.volumeBar = volbar;
   display.seekBar = seekbar;
   display.skin = "MinimaUnderPlayBackSeekCounterVolMuteFull.swf";
   display.autoPlay = false;
   display.addEventListener (VideoEvent.READY, videoReadyHandler);
   display.addEventListener (VideoEvent.SCRUB_FINISH,videoUpdate);
   display.addEventListener (VideoEvent.PLAYHEAD_UPDATE ,videotime);
   display.addEventListener (MetadataEvent.CUE_POINT, cuePointHandler);
  private function onDataHandler ( evt:Event ):void
   xmlData = new XML(loader.data);
   display.source = String(xmlData.video);
    Apr 13, 2011 2:01 AM   in reply to qdjch
    Hi
    This can be a nightmare -  Error #1009 basically means your trying to use something before it exists.
    Your constructor - public function course1(val:String):void expects a value sent to it.
    Your instantiation doesn't send one - myCourse:course = new course();
    Secondly - I don't see a public method to set myCourse.course1("Chapter01-1/Session01/config/Config.xml");
    Either send - myCourse:course = new course("Chapter01-1/Session01/config/Config.xml")
    or
    Remove the value from the call - public function course1():void
    and make a public setter method
    public function set course(value:String):void
      _course = value;
    Hope it helps
    Apr 13, 2011 4:40 AM   in reply to qdjch
    Hi
    OK - now your getting confused between a Class Constructor and a Class Public Method.
    A Class MUST be defined with the same name in the Public Class definition and the Constructor: for instance
    package
    imports.............
    private var _newCourse:String;
    public function course():void
    // initiate vars and listeners for example here
    // This allows you to externally set the course path.
    public function set newCourse(value:string):void
    _newCourse = value;
    _xmlPath = _newCourse;
    In your document class or on a Frame enter -
    var myCourse = new course()
    myCourse.newCourse(pathtoxml);
    addChild(myCourse);
