Here is a tool to easily package a swf for AIR 2.6!
Mar 31, 2011 8:19 PM
Hi all,
I have written a win32 app to compile your swf for iOS using AIR 2.6.
It basically is a replacement for the iPhone settings in CS5.
It means you don't have to use the command line ADT or compile scripts, and it writes the app descriptor XML for you.
It is not quite ready yet (it works, but I haven't implemented launch screens yet).
If there is interest from people here I will finish it and make it available for free.
Android support is on the way too.
No Mac version unfortunately.
Anyone interested?
Replies 1 2 3 Previous Next
    Apr 1, 2011 12:22 AM   in reply to Pea
    im sure you will have people chew your hands off
    i would if you made a mac version :-)
    Apr 1, 2011 12:30 AM   in reply to joeboy_uk
    Welcome!!!! Make it available soon!
    Apr 1, 2011 3:42 AM   in reply to Pea
    Sounds Great. Please let us know when it is ready!
    Apr 1, 2011 5:06 PM   in reply to Pea
    It'd be real useful!
    Apr 3, 2011 9:41 AM   in reply to Pea
    Sounds great. I'm assuming that although I'm on a mac, I can just boot it up on my spare PC and package it there.
    Apr 9, 2011 7:43 PM   in reply to Pea
    Hi Pea
    I'd like to add my vote to this and say I'll be really interested to see what you come up with.  Any update as yet?
    Cheers
    Peter Robertson
    Apr 10, 2011 11:53 PM   in reply to Pea
    waiting here
    Apr 12, 2011 5:30 AM   in reply to pekingman2011
    I'm waiting, thanks
    Apr 12, 2011 8:39 AM   in reply to Pea
    Until Pea will publish his tool, you can download a similar tool that I have created at my work place.
    (Cheers for them, allowing me to share it with you guys!)
    http://rapidshare.com/files/457091918/CreateIPA.zip
    inside there's an sfx rar file that extracts its files [bin+templates] to a temporary folder and runs from there, so no install is needed.
    you can open the .exe file using winrar and edit the templates it you want.
    Enjoy.
    Apr 12, 2011 11:04 AM   in reply to BarakHarel
    Thanks alot BarakHarel.
    I will download this when I am next on my PC, is there any chance of a mac version?
    Apr 12, 2011 11:34 AM   in reply to BarakHarel
    I've forgot to mention a small but important thing!
    inside the .exe archive there are 2 template files, one for the xml and a second for the bat (batch) file.
    you'll need to edit them so they'll point to the correct paths:
    to to so, right click on the CreateIPA.exe [after you've extracted it from the zip file] and select "Open with Winrar" (yes, you should have winrar installed to do so...). you will then see the 3 files that are inside the exe archive.
    in template.xml, you should only edit the <copyright> tag.
    in template.bat, you'll need to edit:
    1. the path to the AIR sdk\adt [...\AdobeAIRSDK2.6\bin\adt]
    2. the path to the certificate and its password (the values after -keystore and -storepass).
    after you've edited them, you can put them back to the exe archive (again, using winrar), or simply place all 3 files in the same folder (the CompileIPA.exe and the 2 templates).
    if you guy's will find this to complicated (you shouldn't), I'll upload a more user-edit friendly version tomorrow.
    and again, the file structure is:
    CreateIPA.zip ->
         CreateIPA.exe ->
              1. CompileIPA.exe
              2. template.xml
              3. template.bat
    but you can extract the 3 files to some folder and run them from there.
    Apr 12, 2011 3:21 PM   in reply to Pea
    Hi pea,
    This looks really good but I think I am missing something. I keep getting the following error when it tries to run the build.bat file.
    'adt' is not reconized as a command.
    Any ideas of what mistakes I'm making?
    Apr 12, 2011 6:51 PM   in reply to Pea
    Cool tool! But in my 64bit system, I have to manually change the command to
    "C:\Program Files (x86)\Java\jre6\bin\java" -jar "I:\Software\Adobe\AdobeAIRSDK2.6\lib\adt.jar" ...
    If you can add the support for 64bit system, it would be much prettier.
    Apr 12, 2011 7:39 PM   in reply to Pea
    It used 64bit Java virtual machine. Then, in the virtual machine, package the swf file by adt.jar.
    u can find it at the AIR 2.6 SDK folder:
    Of cause, you should install Java Runtime 64bit first in your system.
    Apr 12, 2011 10:51 PM   in reply to Pea
    I tried it. An error came up while the bat file running(screenshot attached).
    After I change
    The bat file ran correctly.
    I'm glad to make friend with you. Here's my MSN:
    Kejiachen@hotmail.com
    Apr 13, 2011 10:33 AM   in reply to Pea
    EDIT:
    I did have a problem but then realised I was using the wrong p12.
    Now everything works perfectly. Thanks alot Pea. Great Work!!!
    Apr 13, 2011 2:42 PM   in reply to Pea
    Hi Pea. Thanks for the tool. I'm running it but no ipa is created, any thoughts?
    the log from your tool states the following:
    Deploying for iOS
      check AIR SDK path: ok
      check swf path: ok
      check password specified: ok
      creating output folder (XXX)
        copy XXXXXXXXX.swf
        copy icons/icon29x29.png
        copy icons/icon48x48.png
        copy icons/icon57x57.png
        copy icons/icon72x72.png
        copy icons/icon512x512.png
      creating app descriptor XML
      save XXXXXXXXX-app.xml
      create build.bat
      run build.bat
    thanks
    Apr 13, 2011 2:58 PM   in reply to Pea
    Not unless I double click on build.bat in the ios folder myself. And even then it flashes up and disappears.
    Apr 13, 2011 3:25 PM   in reply to Pea
    ' java' is not recognised as an internal or external command, operable program or batch file.
    I'm runing Windows 7 using parallels for mac.
    Apr 13, 2011 3:50 PM   in reply to Pea
    I don't have the 'Use Java (adt.jar' check box ticked.
    If I do indeed need to set the Java path, where do I link the Path to JAVA (JRE) to? is it something I need to download from Adobe?
    Apr 13, 2011 4:17 PM   in reply to Pea
    I tried using ADT in terminal, but it goes right over my head. I'm a designer not a coder
    Apr 13, 2011 4:26 PM   in reply to Pea
    Thanks. After installing Java, it seems to be doing something
    Apr 13, 2011 4:39 PM   in reply to Pea
    After a long wait, a shiny new IPA appeared. Thanks Pea, you are a star!
    Apr 13, 2011 8:14 PM   in reply to Pea
    Sorry, I used my email to reply you. It seems the forum cut off some contents in my mail. My change in line(3) in the xml file:
    <id>Weather AIR 2.6</id>
    <id>WeatherAIR26</id>
1 2 3 Previous Next
Actions
