So, I just got off the phone again. Had to restart at Level 1. Had to rexplain and demonstrate everything. Only to be told after 40 minutes
that they will re-escalate to level 2.
Is there a solution for this?
It seems the things I am seeing on this thread are often contrary to the beliefs of the support on the phone. Does the information from these threads get disseminated to the phone support?
Brad
I've been having the same issues - have tried working with Adobe support and with Ravi Tak but still don't have a solution.
I have the eLearning Suite 2. I didn’t install Presenter when I got it because I didn’t think I would use it – I use Articulate Presenter. However, one of my clients wants to use it so I am trying to install it on my computer so I can show him how to use it in conjunction with Adobe Captivate. I use PowerPoint 2010 32-bit version (screen shot on the word document).
1. I tried installing Presenter from the Suite install. Didn’t show up in PowerPoint.
2. I uninstalled it from the Suite install.
3. Downloaded the version from the Presenter page - http://www.adobe.com/products/presenter/?promoid=DJDXB.
4. When I tried to install the build, I had to first insert my serial number. I used the eLearning Suite serial number. It didn’t like it.
5. I searched the forums for any information on this problem and didn’t find a solution.
6. I contacted Adobe Tech Support – see chat transcript below.
7. I tried what the tech suggested – installing the Adobe Presenter base installer. It asks me for my serial number. I used the eLearning Suite serial number. It didn’t like it.
8. I tried the Office2010_eLS@_zip file and reinstalled Presenter from the Suite. Didn’t show up in PowerPoint. Uninstalled it from the Suite.
9. I tried installing it as a trial version using the Adobe Presenter base installer – it worked.
10. I downloaded each of the patches and installed them in order.
11. I opened a presentation and Presenter is on the ribbon bar. Yea!
12. I get the "Adobe failed to open because it is not licensed error.
13. Unistalled Presenter.
14. Tried the install with right-click, compatibility bar solution. I don't see the "XP Sp3 32 bit" solution as suggested - see "previous versions of windows" as an option.
15. Just got another suggestion to again do the Office2010_eLS@_zip file and reinstall Presenter from the Suite. Didn't show up in PowerPoint.
I am just about tired of trying!
Ravi, et al.,
I'd like to suggest a regroup on this.
The goal, I think, is to produce a Presenter app that will be compatible with Powerpoint 2010.
Presenter works just fine on Powerpoint 2007.
My thought: Rather than drill and drill and drill into settings and registries and workarounds with patch after patch after patch; I for one, could wait a month, or two, until:
Until you come out with Presenter 8. Something that you've bulletproofed to death and know will work, period, end of story.
What say you?
Glen Gummess
P.S. I would expect a serial number. I entered it with Presenter 7, with the workarounds, and it took. The problem is that Presenter 7 just doesn't function with Powerpoint 2010. It breaks.
I, too, continue to work with Adobe in finding a solution to these problems. In my capacity as an instructional designer I work with numerous faculty at the University of St. Francis in the implementation and effective use of Adobe Presenter and Adobe Connect. However, the first crack in the dam has appeared: Doctoral students in nursing are charged with the task of using Presenter to make professional presentations. I have already begun to hear from some of them about the travails of installing Presenter with Powerpoint 2010. Here is one student's message:
All,
While I have not received a fix from Adobe, my IT Director did solve my problem.
For now, I am running a Windows Virtual Machine with XP and Office 2010. I ran the Presenter Installer for 2010, all of the patches in sequence, and I am up and able to work.
If you have an XP license laying around, it works as a patch for now.
Brad
Hi Everyone,
Finally we have got a bug [Bug# 2841496] logged for this issue. I would recommend you guys who have the licensed version of Adobe Presenter to call in Adobe Support and log a ticket for this issue. This will help them in increasing the priority of this bug and get us a fix soon.
Ravi
I performed another way to diagnise this issue today.
I bought a new hard drive and a new Windows 7 (64-bit) full install software installation.
I started with a new hard drive--no other hard drives in the system-- and did a fresh installation of Windows 7 and Office 2007.
All went well.
Then I installed Presenter 7 from the Adobe web site. It installed into PowerPoint 2007.
Then I tried to add a recording to a PowerPoint 2007 presentation. I received the same error message that I received when I started this thread.
Since this is an installation on a new machine how can this occur? Is there something wrong with Adobe Presenter 7 on Windows 7 64-bit? I do not have any other software on the hard disk other than Windows 7,Office 2007 and Presenter.
Very confused by this software issue.
Regards...Dave
I spent the afternoon on the phone with Adobe support after installing but failing to run Adobe Presentation on a Win 7 machine with Powerpoint 2007. I'm now waiting for a call back. The license agreement comes up fast and tantelizes you, then leaves.
I tried installing on my laptop after I got home. Same results, but the machine is a tad slower, and I can just read the agreement, but it leaves too quick to click on the "agree" button.
I'm waiting for a Tier 2 call back ...
Hi Ravi,
I purchased the e-Learning Suite2 and MS Office 2010. I installed both on a new PC.
I posted a comment in another post about Windows 7 2010 compatibility with Presenter 7. It looked like the installation went fine, but I could neither see the Presenter application in my Start window (like I can with all of the other eLearning Suite applications).
I clicked open the Adobe application folder on my hard drive and can see a folder for Presenter 7.
The folder contains a Presenter Windows Installer. So I double-clicked that and got the installation wizard for Presenter.
When I started, it asked me to close PowerPoint which I did. I then got as far as the screen asking me to enter my serial number and when I enter the number on my eLearning Suite CD (the one I used to install the other eL2 applications), I got an invalid serial number message.
Any suggestions?
mindforge
Hi mindforge
Please see my response to the other thread http://forums.adobe.com/message/3608423#3608423
thanks
Nirupam Tewary
Adobe Systems
For the issue where Adobe Presenter opens and thereafter throws the "unlicensed" message, please try the following steps:
Please update the forum with your observations. Make sure to keep the backup in #1 handy.
Nirupam Tewary
Adobe Systems
Following is the amt.log of the computer that is not working. The first part (in bold) is the same as on the computer where "Presenter 7" is working correctly, the rest is different.
Please help
2011-04-13 10:27:37 [3092] AMT: START SESSION, library version 1.5.0.36,52.341579
2011-04-13 10:27:37 [3092] AMT: Initializing C:\Program Files (x86)\Adobe\Presenter 7\ [en_US]
2011-04-13 10:27:37 [3092] AMT: Adobe License Manager version 2.5 (build 1.36) RELEASE
2011-04-13 10:27:37 [3092] /AMT0250984558/ {4F93ABBE-5A1D-4D56-94CB-022F109FDE4D}
2011-04-13 10:27:37 [3092] /AMT0194694755/ {4F93ABBE-5A1D-4D56-94CB-022F109FDE4D}
2011-04-13 10:27:37 [3092] /PCDService0127063747/ {4F93ABBE-5A1D-4D56-94CB-022F109FDE4D}
2011-04-13 10:27:37 [3092] /AMT0073107491/ {4F93ABBE-5A1D-4D56-94CB-022F109FDE4D}
2011-04-13 10:27:37 [3092] /AMT0087759331/ {4F93ABBE-5A1D-4D56-94CB-022F109FDE4D}
2011-04-13 10:27:37 [3092] /AMT0051932803/ License-GUID-Presenter-Win
2011-04-13 10:27:37 [3092] /AMT0186350190/
2011-04-13 10:27:37 [3092] /AMT0217686206/
2011-04-13 10:27:37 [3092] /AMT0013778542/
2011-04-13 10:27:37 [3092] /AMT0141832179/ C:\Program Files (x86)\Adobe\Presenter 7\AMT
2011-04-13 10:27:37 [3092] /AMT0166617427/ C:\Program Files (x86)\Adobe\Presenter 7\AMT\application.sif
2011-04-13 10:27:37 [3092] /AMT0268432926/
2011-04-13 10:27:37 [3092] /AMT0172021198/
2011-04-13 10:27:37 [3092] /AMT0201805758/
2011-04-13 10:27:37 [3092] /AMT0013754766/
2011-04-13 10:27:37 [3092] /AMT0232480894/
2011-04-13 10:27:37 [3092] /AMT0126557118/
2011-04-13 10:27:37 [3092] /AMT0125289710/ Obtaining
2011-04-13 10:27:37 [3092] /AMT0011178590/
2011-04-13 10:27:37 [3092] /AMT0211681639/
2011-04-13 10:27:38 [3092] /AMT0049118148/
2011-04-13 10:27:38 [3092] /AMT0165767982/
2011-04-13 10:27:38 [3092] /EPICService0071286754/ EULAFolderName Legal
2011-04-13 10:27:38 [3092] /EPICService0078689294/
2011-04-13 10:27:38 [3092] /AMT0247102670/
2011-04-13 10:27:38 [3092] /AMT0232480894/
2011-04-13 10:27:38 [3092] /AMT0056200073/
2011-04-13 10:27:38 [3092] /AMT0118780867/ PresenterPresenter{4F93ABBE-5A1D-4D56-94CB-022F109FDE4D}{4F93ABBE-5A1 D-4D56-94CB-022F109FDE4D}
2011-04-13 10:27:38 [3092] /AMT0171050355/ 684.406043
2011-04-13 10:27:43 [3092] AMT: END SESSION.
same problem on 4 pc's here...
surely the install files have changed at some time because I've had Presenter 7
working on Windows 7 with Office 2010 for ages...
then we upgrade our pc's to CS5 so I reinstalled everything from scratch and now
it will not work on any of them!
this is completely unacceptable in my opinion, why is it that other Adobe products
are patched regularly but good ol' Presenter always has something wrong with it?
I've been using this for years and there is always an issue somewhere.
please Adobe fix this bs 'cuz I'm getting hassled from all sides and can do nothing about it!
...same problem on 3 pc's:
Windows Vista 32bit, Office 2007 32bit
Windows 7 32bit, Office 2007 32bit
Windows 7 64bit, Office 2010 32bit
Now I have found an old installation file of Presenter 7.0 on a backup-drive from 2010-09-27 and it isn't work as well... very confusing.
Please fix this asap @Adobe, I have to finish some product-presentations until upcoming week!
Hello Everyone,
I have successfully installed Windows 7, Office 2010 and Presenter 7 on a 32 bit machine. I was able to record and publish.
I did not do anything to the registry. Most of our users would have a problem with doing this. Make sure you update your Windows 7 to service pack 1. I also updated PowerPoint with a security patch. Then you need to install presenter 7. If you have installed presenter, you need to uninstall it. I was able to record on several slides and then publish.
I hope this helps everyone.
Chris
Hi Chris Support (are you Adobe Support?)
This is well meant but does NOT help.
I have two computers, both with Win7 64bit and both with PP 2010 32bit. On one computer Presenter 7 installed works correctly but on the other one I get the error described above.
I have uninstalled Presenter 7 and cleaned my computer with CCleaner MANY times and YES I do have SP1, as I think there is an old file which Presenter did not uninstall.
So, will anybody from Adobe please respond?
rg
I have 4 brand new edit stations for our media center at work and Adobe Presenter
works on none of them!
They are Windows 7 64bit with Office 2010 32bit.
Our Presenter output has ground to a complete halt... we'll be looking for
alternatives after this episode as Adobe Presenter has never been anything
other than a bug ridden pos.
I have the same problem.
Running Windows 7 Professional (64-bit) with PowerPoint 2007 (32-bit). It worked previously on my laptop when I was running 32-bit version. But, moved to 64-bit due to application requirements (needed to be able to access more memory). The software works on my desktop (Windows 7 Home Premium 64-bit) but not on my laptop. Could it be the difference between Professional and Home Premium?
Adobe told me they would not help me since I am running 64-bit OS and Presenter is not certified on that. This answer came after 6+ hours (over a few days) of talking to many different support technicians.
Not good for us. We rely on Presenter to create content for our meetings in Connect Pro. With it not working, we may be forced to re-evaluate using Connect Pro.
Presenter makes it easy to create the type of content we want. We had no problems with any of this until March of this year.
Sadly, Adobe is not investing in Presenter. It would not surprise me if they are getting ready to drop it all together.
The latest eLearning Suite has the same version 7 as the Suite we purchased 2 years ago. I have uninstalled / reinstalled.
Please figure out an answer (anyone???).
I think that before we throw Adobe Connect Pro under the bus there are a couple of points that should be made.
First of all, we're talking about Presenter here, are we not? Not Adobe Connect Pro virtual meetings, right? They are two different things that reside on the same platform.
I am running Adobe Connect meetings on my Windows 7 32-bit machine. It is the same machine that Chris, my colleague, was working on. I also recorded a test presentation using Adobe Presenter after she was done doing what she has described, and it all worked, seamlessly.
There IS a solution.
I think that what Adobe needs to do is:
I'm sure this is easier said than done. The reason for me posting this message is simply to suggest that while this may be a huge bug for Adobe to fix, it is fixable. But as I said in an earlier message in this thread; Adobe CANNOT ALLOW THIS TO LANGUISH. Our users at my shop are faculty, and faculty are fickle technology users. If there is no fix to this, they will abandon it and move on.
Lastly, I just want to say is that there some pretty smart guys at Adobe who are good at what they do. Now they've got to prove it again.
Glen
Dear Adobe Presenter users,
It seems that there is somewhat of a mix-up in this thread. There are 2 issues being discussed -
1. Presenter 7 is installed and licensed but when you access it inside PowerPoint, it throws the message that it is not licensed and does not let you proceed. This thread is for this particular issue only. There is a bug report in the Adobe bug database for this issue as well and is being actively looked into.
2. Installation fails or installation completes but Presenter does not appear inside PowerPoint. This issue mostly seen on 64 bit machines and it is for this issue that certain registry changes are being suggested. The thread for that issue is http://forums.adobe.com/message/3608585#3608585.
Thank you for using Adobe software and reporting the issues. We are confident of identifying appropriate resolution to both issues soon.
Nirupam Tewary
Quality Manager, Adobe Systems
I am a bit dissapointed not hearing from Adobe on this. In the meantime I have done a bit of hacking.
This is how I got around the problem were 'Presenter 7' brings up the EULA page for too short a moment to be able to accept it, and then thinks it was declined, and subsequently shows an error saying: "Adobe Presenter failed to open because either it is not licensed or there is an error".
So I hacked the EULA html file (see below)
After installation of Presenter 7, replace the content of the file
C:\Program Files (x86)\Adobe\Presenter 7\adobe_epic\eula\install.html
with the following content, where the line in bold is the important one
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>License Agreement</title>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<link href="./../default.css" rel="stylesheet" type="text/css">
<script language="javascript" src="./../domutils.js"></script>
<script language="javascript" src="./../wizardcore.js"></script>
</head>
<body onload="doAccept()" background="./../background.png">
</body>
</html>
This will accept the EULA automatically and enables you to work afterwards.
This is not a fix, but a work around.
This worked for me and I do not accept any responsability. Obviously Adobe also thinks you are on your own.
rg
