Hello!
I have installed FlashBulder 4 as standalone and I activated him.
How to update FlashBulder 4 to FlashBuilder Buritto?
Can I install Butitto without removing the FB 4?
Do I need to deactivate FB4 before installing Buritto?
Do I need to uninstall FB4 before installing Buritto?
Hello,
Flash Builder 4 is the currently released version, and Burrito is a Preview (Beta) version, that can be installed alongside FB4. There's no need to uninstall FB4 before installing Burrito, or vice-versa.
They install into separate locations by default, and will run independently from one another. Licensing is also independent - Burrito will run in its own trial period until you activate it with a serial number. You can use your FB4 SN to activate Burrito, without affecting your existing FB4 activation.
-Chris
will FB4.5 be a chargeable upgrade from FB4? And I currently use FB4 alongside Dreamweaver (for PHP coding only) - will there be an upgrade path from that combination to FB4.5 for PHP?
I'm having troubles activating Buritto.. I was able to get a new serial for Paninni.. and the site says too follow the same process for Burrito.. I do, and get the same serial which does not work..
Any ideas?
I called customer support and they said to post here..
Todd
What is the error message you are seeing when you enter the serial number?
Can you please send me amt3.log and oobelib.log files? They are located under %temp% in win and /tmp in Mac.
Also may I know which burrito build you are using and how you obtained the serial number?
Please mail the details to me at deeptika (at) adobe (dot) com.
Deeptika
