Reader can't sign pdf signature field
Apr 5, 2011 2:20 PM
I am using LiveCycle Designer V 8.2.1
I have added a signature field in a new form I am creating.
The problem is you can not sign the pdf in Reader X. It does nothing.
I have another form that was created by another user who is no longer here and you can add the signature.
When I open it is Acrobat 9 Pro, I can sign.
Any ideas on what I am doing wrong?
    Apr 6, 2011 5:28 AM   in reply to procnc645
    You cannot digitally sign a PDF with Reader UNLESS the PDF has been  "Reader Extended".  This can be done using LiveCycle ES2 Reader  Extensions (server product) or Acrobat Professional X (File > Save As  > Reader extended PDF)
    Regards
    Steve
    Apr 18, 2011 12:50 PM   in reply to SForrest96
    Hi Steve,
    could that signature be a safe, secured, digital signature or does it need a certificate?
    Would I need to set up this digital signature in some way?
    Apr 18, 2011 1:24 PM   in reply to msz123
    I'm not clear on what you are asking.
    To sign a PDF, either with Reader or Acrobat, the person siging the document must have a digital identity (digital certificate, public\private key pair) to genearte the signature.  There are various ways to store the digital certificate, such as the Windows Certificate store, in Acrobat or Reader you can browse to a digital ID, the digital certificate may be stored on a USB key etc.
    For the recipient of the signed document to be able to properly validate the signature, they must "trust" the digital certificate (public key) of the signer.  The public key is embedded in the digital signature itself, and typically you configure a "Trusted Identity" in Reader\Acrobat for the signer.
    Regards
    Steve
    Aug 16, 2011 4:42 AM   in reply to SForrest96
    Thanks for the help with this! I was searching in vain for why my signature panel wouldn't allow for the actual signing. I was only able to leave empty forms which didn't help for signing.
    In the future, you may want to suggest this as a default save format any time a blank signature form is added.
