F4v output not convertable from CP5
Apr 12, 2011 1:06 PM
I've been asked to put a quick presentation I had already made in CP5 onto a DVD to play in a normal DVD player. I do not have Media Encoder and have no way of getting it. The presentation had a small amount of interactivity - links to webpages, emails, etc and one fork in the road that would either jump over 7 slides or not.
So, I can do without the links and tried to resolve the other element by creating 2 separate videos and sticking the choice in the DVD menu via iDVD. Once I have the fixed-rate f4v output, I have used a couple different ffmpeg based converters to put the videos in iDVD.
Now here's the weird part: The shorter presentation (missing 7 slides + the decision slide = 8 slides hidden) exports fine, converts fine, burns fine. The longer presentation does not. The f4v is playable in VLC, but not transcodable. Converting using Handbrake gives me a 4KB blank file (in contrast, the shorter presentation file size is 11.5MB - plus 4KB is just too small for anything). Evom fails for some output file types, appears to succeed for others, but the output is a blank green screen.
The added slides are only audio, images and text captions - what could be causing this?
    Apr 20, 2011 1:41 AM   in reply to klepi_8
    Cant think of any solution as yet but can you just try copy pasting the slides and create a new project out of it. Then publish to F4V and see if it works.
    mukul
    Aug 2, 2011 10:36 AM   in reply to klepi_8
    I'm seeing the same behavior, some F4V files from Capitivate encode/convert fine in ffmpeg, some don't.
    This is a strange one. Posted a copy of the source to
    http://markusbucket.s3.amazonaws.com/watch_s3_source/5924_doesntwork_e Bay_orig.f4v
    Tried running plain html5 outputs, Apple Compressor, QuickTime Player 7/X (Mac 10.6.5), Handbrake... all failed to output correctly. The strange thing is that both VideoSpec and MediaInfo seem to report it as a plain ol' h264/aac file.
    Please let me know if you've found a workaround, or if Capivate allows export to formats other than just these misbehaving F4Vs.
    Thank You,
    Markus
