I have Adobe Photoshop Elements 9.0 installed on my Windows 7 computer and have recently started getting a message that I believe may be associated with that program. The message reads "CAHeadless Debug Event" "CAHeadless has encountered an error - [..\..\Src\DataManager.cpp-410]"
Does anyone know what may be causing this message and how to cure it. I am able to click the Continue button and everything works as it should but it is a little annoying.
Patrick
Message title was edited by: Brett N
Glad that I am not the only one. I have the message on the forum since Dec 10,2010 with 30 reads but 0 answer. I wish both of us luck.
George
LINK: http://forums.adobe.com/thread/764040
Message was edited by: Brett N
Hi Patric,
I am adding here part of message I received :
Wednesday, December 15, 2010 8:44:05 AM PST
Hi George,
Thank you for your patience. I can understand that it must make you feel
upset and we will work toward fixing this situation for you.
Please try the following steps:
> It seems that it is a catalog issue.
To create a catalog:
1. Make sure that Premiere Elements and the Photoshop Elements Editor
are closed.
2. Open the Catalog Manager.
3. In the Catalog Manager, click New.
4. Type a name for this new catalog and then click OK. The Organizer
opens with this new, blank catalog
Itwork for me! I hope that you can do the same. In my case it was the 'Catalog' issue.
George ![]()
You might like to know that I tried a different forum with this problem and had a reply that suggested I do the following:
are closed.
opens with this new, blank catalog.
That’s it then you can go back to the original catalog. No guarantee as I’ve just tried it and haven’t had long enough to know if it works or not.
Hope that may be of some help.
Patrick
Sent: Sunday, December 12, 2010 4:48 PM
To: Patrick Dyer
Subject: Re: Error message Error message
I am having the same issue. I would really like to find out why as well!
Thanks, Amy
I am also having the same CAHeadless Debug error on PSE 9.
Switching catalogs does not help.
Turning off face recognition does not help.
I have looked through the forums and on the internet and it seems that this is a common problem for PSE 7, PSE 8, and now PSE 9.
Does anyone have a solution?
What do you guys expect ? I have the same error, besides others, Tried the same like you guys, did not help After 30 yrs IT, I think I have rarely seen such an obsolete, unintuitiv and error prone product. Especially this organizer is a pain in the behind. Fit's my feelings about Adobe products as such.
Thanks for the advice. Tried this twice; it did not work. The error message reappeared when I used PSE 9. Many other subscribers to PSE 9 seem to have the same problem. It does not affect the operation of the program, but it is just another one of those nagging problems the original software manufacturer should address.
Date: Wed, 20 Apr 2011 12:44:41 -0600
The problem is with the auto analyzer. It recently turned this on and the message started appearing - now turned it off and the message gone away! Turn it off in your preferences under Media Analysis.
I have the same problem on my system, but it seams to be soved according to the instructions of Mr. William Mahar.
- Also a problem for me in the same connection is, that if I open a file of 2011, the PSE shows up with files of 2009. I thought it could be also a problem of the media analaysis. I shut them off in the preferences, but this problem still occurs.
- An other problem is that I can't download Adobe Help since several days, even a fortnight. My PSE9 has been delivered with the help files of PSE8. Up to now I have not found any answer in a forum
Dear Sir,
I have taken the advice as given in the http://forums.adobe.com/message/3719177#3719177 by William Mahar
It worked. I really do hope that it does also with 409.
PSE9 is still a mess. Previously I used Ver. 2, 4, 7, 8 and now 9, always hoping the new version would be improved and having less bugs. But unfortunately I got always disappointed.
I too am a user of Photoshop Elements9 installed on my Windows 7 computer. I recently encountered the CA Headless 410 Problem. I tried the trick of creating a new Catalog and then going back to the original. I have also tried turning off the Media Analysis. No help.
The pressing the continue button when the error message appears allows you to keep on working in Organizer. But if you tried to create a video with music it then closes the program down no matter what I have tried. Has anyone come up with a new solution that works?
Thanks.
Bob Frustrated
I got a similiar message which I thought used words "headless bug" but it was probably debug.
I more often get the following whenever I go to create a new album in the Organizer:
"A problem occurred while loading this album template. An auxilliary file may be missing or damaged. Please reinstall the application to correct the problem."
Then I click OK and I can go ahead and create the album. So everything still works but why does this meaningless message appear up every time???????????????????????
I think I solved the problem...
Try this: Go to your C:\ drive and then the following folder:
C:\ProgramData\Adobe\ElementsOrganizer\Catalogs -
Remove all remaining folders inside the Catalogs file (or just drag them out to your desktop)
Open Elements and then the Organizer -
A window opens and tells you to enter a new Catalog.
Do so in another place, like another drive... (I tried one on the C:\dive and got the same message.)
That's it...
No further problems for a few weeks now. Looks like that's it...!!
I'm having the same problem in PE10, and along with the error message none of my thumbnails are loading into the organizer. It's as if the catalog was empty ecept in the lower right hand corner is says there are 12,092 itemes dates Jan 1980 to May 2012 so there are there somewhere.
I just moved from a PC to a MAC and had to carfully and manually import all these photos because while you can import the tags you can not import the Albums from a PC to a MAC. It took me at least 10 hours!
Anyway does anyone know how to get the thumbnails back? I'll die if I have to start from scratch!
It didn't migrate it. I was able to attached the tags to the individual pictures on my old PC and most or them came along when I imported them on my MAC. I had to rebuild the my Albums from scratch however since my photo folders were already organized by year and event "Vacation", "Graduation" and so on that was doable. I did not want to load all my photos im photoshop so selecting the ones to bring in took a great deal of time.
I just completed loading the last of the photos and decided to run the Optimizer, Repair and re-indexer of simmilar data on the catalog. The next time I opened PE10 the thumbnails were gone.
Same with me! Organizer is screwing up and getting those errors are a pain in the ***. I see people are saying make a new catalog. Going to try that. Hopefully this glitch gets solved. While the organizer is handy at times...I get pissed off wondering ....hmm is today the day that my pics all poof into the Glitched Organizer Zone. Thanks everyone for the info about Creating new catalog. Going to try that.GL to everyone with the same issue. ![]()
If you have yourself set up as a normal user (as opposed to an adminstrator) in Win 7 or Vista you may want to try disabling any PSE autostart programs and then use the "run as administrator" to run PSE. This has the unfortunate effect of undoing the security you gained by creating and using a non-administrator user. It has the positive effect of allowing poorly written (from a security point of view) programs to run with fewer errors. (This 'trick' works with many programs, Adobe are far from being the only company who have taken shortcuts with user permissions with coputer programs.)
Apologies, if I sound irritated, I have spent a large part of today fighting ridiculous erros in PSE (eg Organizer decided to refuse to refuse to import pictures because it 'did not support their colorspace'. The fact that the other 130 odd photos I took at th esame event with the same camera and camera settings was seemingly irrelevant. I was also having problems with deleteing photos from PSE Organizer because 'the file is open in organizer'. Finally, I sent a photo to the editor for editing and could not save the file to th esmae filename because, yes you uguessed it, 'the file is open in organizer'.
I have over 37,000 photos in Organizer, and the thought of having to import and tag them again is pretty muc the only thing stopping me from tossing PSE and using an alternative.
Wow, I just looked at the stats for this more closely, 9,510 views since PatrickDyer44 posted the initial query on 7/31/12!
The next highest number of view I saw for a discussion in my quick glance through the first few pages was 308. I guess this CAHeadless really is causing a problme for a lot of people. With luck Adobe monitor these forums and act issues that seem to affect large numbers of people.
