ThePulp75
Problem with Acrobat type library 10 with VB6 on Win7 64bit
Apr 14, 2011 6:54 AM
I'm trying to use the Acrobat type library 10 in a visual basic 6 source code on my Windows 7 64bit.
On the web I found many examples, and specifically i'm trying this one:
        'IAC objects
        Dim gAvDoc As Object
        Dim oPagesSrc As Long
        'variables
        bleFound = False
        ioutfile = FreeFile
        'hard coding for a PDF to open, it can be changed when needed.
        gPDFPath = "C:\Documents and Settings\....." ' FILL IN YOUR PATH HERE
        'Initialize Acrobat by creating App object
        Set gApp = CreateObject("AcroExch.App")
        gApp.Hide
        'Set PDDpc object
        Set gPDDoc = CreateObject("AcroExch.PDDoc")
But running this code I always get an error message: "the component can't create object" for line:
Really I don't know how can I fix....
Many thanks
    Apr 14, 2011 7:05 AM   in reply to ThePulp75
    We don't support VB6 with Acrobat X.
    Apr 15, 2011 8:22 AM   in reply to ThePulp75
    Depends on what you want to do.
    If you simply want to view a pdf file, that still works using the ActiveX component.
    I have not seen problems in changing versions of Acrobat or Reader, since the ActiveX takes care of the viewer.
    Apr 21, 2011 2:45 AM   in reply to ThePulp75
    The 64-bit system should not prevent you from using the ActiveX.
    But it is clear that VB6 is not the best choice if you are starting a new project. And Reader is not sufficient.
    If you simply want to check if the ActiveX works.
    Select the (Adobe .. Library) Reference/Component : this should put the AcroPDF element in the toolbox
    Drag the AcroPDF from the toolbox to your form
    Code to Load a file :  AcroPDF1.LoadFile "yourFile.pdf"
