Hello to all;
I need some support with LiveCycle for Mobile on Apple iPad. In the app's main menu, when i log in to the Livecycle server, there should be 3 tabs (Tasks, Forms and documents), but i can see only the Tasks tab.
I have set the following user permission for the test user:
Thankks in advance for your answers ![]()
Darklight3it
Another Question....
In order to test the Tasks functionality I've made a simple process that assigns a task to the test user. The problem is that the notification does not appear on the iPad even if it's notified on the Workspace.
Did i miss some important detail in the assign task options?
Hello,
Check out the help page here: http://help.adobe.com/en_US/LiveCycle/9.5/WorkbenchHelp/WS92d06802c76a badb-1cc35bda128261a20dd-7dbf.html
I suspect that the issue is that you have not configured the Assign Task or Assign Multiple Tasks operations to allow tasks to be completed without opening the form or Guide. That check box has to be set so that the mobile device sees the task.
Also remember to put in good quality Task Instructions, as that text is typically the primary way of indicating what is to be approved or rejected to the user. The PDF is sent along with the task to the device as an attachment. I like to use XPath to construct a great message, for example:
{/form_data/users_name} has submitted a purchasing request valued at {/form_data/value}. The reason for the request is: {/form_data/reason}.
Good luck!
Matt MacKenzie
Adobe Systems
Darklight3it,
Are you able to see the task for that user via the workspace web interface (e.g. http://lcservername:8080/workspace ) on a desktop/laptop pc?
Do you have any other mobile devices with LC Mobile installed? e.g. iPhone, BlackBerry, Android device.
Howard
Did you uncheck the "Form Must Be Displayed When Completing" before you created the work item? If this setting was not unchecked when the task was created then you would have to re-create the task again for it to be visible. Try re-submkitting the same task (now that the "Form Must Be Displayed..." checkbox is unchecked and see if it is visible on the mobile device.
Done in all of my tests, but still not working.
