I have just tested the samples from the Drive SDK.
The 'HelloWorld' example works fine.
I have then tested the 'sample.basicftp' and even I can connect to the FTP-Server no files or directories were listed.
I also can't write on the FTP-Drive, because it is write protected.
I have activated the debug messages in 'log4j.xml'.
This is a snippet from the output of the log:
ConnectHandler - -->In()
FtpClientHelper - connecting server: xxx.xxx.152.179
FtpClientHelper - connected
ConnectHandler - -->Out()
GetVolumeIconHandler - -->In()
GetVolumeIconHandler - -->Out()
GetConnectionDetailsHandler - -->In()
GetConnectionDetailsHandler - -->Out()
GetAssetsHandler - -->In()
GetAssetsHandler - (assetId:null | parentId:/ | assetPath:/Contents)
GetAssetsHandler - (assetId:null | parentId:/ | assetPath:/mach_kernel)
GetAssetsHandler - Attempting to determine asset type: /Contents
GetAssetsHandler - Attempting to determine asset type: /mach_kernel
GetAssetsHandler - Asset not found
GetAssetsHandler - -->Out()
GetAssetsHandler - (assetId:null | parentId:/ | assetPath:/autoexec.bat)
GetChildrenHandler - (assetId:/ | parentId:null | assetPath:/)
GetChildrenHandler - -->Out()
GetAssetsHandler - (assetId:null | parentId:/ | assetPath:/.TemporaryItems)
GetAssetsHandler - (assetId:null | parentId:/ | assetPath:/.Trashes)
DisconnectHandler - -->In()
FtpClientHelper - disconnected server: xxx.xxx.152.179
DisconnectHandler - -->Out()
I wonder about the asset names 'Contents', 'mach_kernel', 'autoexec.bat' and so on.
There are no files or directories on the remote or local system with these names.
So my questions is:
Is there an error in the sample, or is it me doing something wrong?
Hello,
we are using pure-ftp on our own ftp server.
But I also tested it with some other ftp servers (don't know which server type they are) with the same results.
I have no problems to connect with other ftp clients (Cyberduck, OS X built in ftp client).
My platform is Mac OS X 10.6.7.
I have added some additional debug to the function 'GetConnectionDetailsHandler'.
As I understand, the function sets the ftp server hostname and address.
public void execute(IProgressMonitor monitor,
GetConnectionDetailsRequest request, GetConnectionDetailsResponse response)
throws RemoteHandlerException
LOGGER.debug("-->In()");
FtpService service = this.getFtpService();
try
LOGGER.debug(service.getHostName().toString());
LOGGER.debug(service.getHostAddress().toString());
DEBUG ConnectHandler - -->In()
DEBUG FtpClientHelper - connecting server: xxx.xxx.152.179
DEBUG FtpClientHelper - connected
DEBUG ConnectHandler - -->Out()
DEBUG GetVolumeIconHandler - -->In()
DEBUG GetVolumeIconHandler - -->Out()
DEBUG GetConnectionDetailsHandler - -->In()
DEBUG GetConnectionDetailsHandler - 192.168.30.208
DEBUG GetConnectionDetailsHandler - -->Out()
I wonder why 'service.getHostAddress()' returns my local IP Address.
That can't be right.
Hello,
as I wrote in my last post, I wonder about the local IP address.
Therefore I started my local FTP server on my Mac.
When I connect to my local FTP server everything seems to be alright.
It is just a little bit unstabel because it hangs up my finder two times.
So, could it be that you mixed up client - server in your sample?
Maybe you have also developed and tested the sample in a local scenario?
If the directory that user tries to access has no list priviledge, Adobe Drive will show empty directory, and it's correct. Therefore, you need to check your pure ftp server configuration firstly, then remove your basicftp server in 'Recent Connections' Panel and reconnect it again.
For the issue that service.getHostAddress() returns your local IP Address, you can edit /etc/hosts file, replacing your local address with the actual network address.
As you mentioned that everything seems to be right when you connect to your local FTP server but failed when you connect to your remote FTP server, I tried to set up a pure ftp server on a machine and use Adobe Drive to connect it on another machine, it works well. Maybe you should check your network configuration firstly.
Additionally, we can investigate your problem if you can provide your pure ftp server connection info to us.
Adobe Drive will ping server periodically, you can refer to SDK API: ICheckServerOnlineStatusHandler. Therefore, I think your log is reasonable.
My email address is 'huli@adobe.com'.
Hi Snap-OM,
I used FileZilla ftp client to connect your ftp server, and it showed empty directory which was the same as Adobe Drive's result. Then I used ftp command 'ls' to list the names of the files under the root directory, the console printed '425 Could not open data connection to port 36795: Connection refused'(I had closed my firewall). From this message, I think that you need to open a range of ports in your ftp server's firewall so that client can access ftp contents successfully.
Hui
