Inserting/embedding YouTube Video
Apr 25, 2011 8:40 AM
I'm runing Ct CS4 and according to the documentation, I can insert a video from the web into a page using 'Insert > video > From internet,' after which, "A video placeholder appears in your draft."
I am able to browse to the YT video I want to insert and click 'Ok' but then nothing happens; there is no placeholder and no video when I publish, and no error message, and trying to use the YT Share code results in an error about not being able to insert a directory.
What am I doing wrong? It is a permissions issues?
Thanks in advance for any help.
    Apr 25, 2011 2:47 PM   in reply to scotch123
    I believe you have to link to the actual video file rather than a page the video is located on.
    Apr 26, 2011 1:22 AM   in reply to scotch123
         For embedding Youtube video, you can do the following:
    • Copy the embed code for the video.
    • In Contribute, edit the web page where you want to embed the video.
    • Select Insert -> HTML Snippet menu item.
    • In the resulting dialog, paste the Youtube embed code.
    • Click OK.
    • Now a place holder will be placed for the video, and on publishing the web page, the video can be played by the people visiting your web page.
    Note: HTML Snippet menu item will not be enabled by default, an administrator has to enable it for a particular role.
    Hope this helps.
    Apr 27, 2011 8:58 AM   in reply to scotch123
    Yeah sorry.
    Forgot about Insert HTML snippet. That should do the trick with a youtube video.
    Mar 4, 2012 4:29 AM   in reply to Krishna Prasad B V
    Hope this helps.
    Hello. I'd like to embedd a video (from youtube) and was wondering how I go about enabling the snippet menu. Could you let me know how this is done? I'm the administrator and can't seem to figure this out.
    Many thanks-
    Jim
    Mar 4, 2012 10:41 PM   in reply to pixelfixel
    Steps to enable HTML Snippet:
    1) Administer the site
    2) Select the Role and Click Edit Role Settings...
    3) Choose Editing
    4) Check the option, "Allow HTML Snippet Insertion..."
    Refer to, http://blogs.adobe.com/contribute/2009/06/are_you_a_power_user_try_usi ng.html for more information.
    Mar 5, 2012 3:01 AM   in reply to Dominic Michael
    Got it--worked great!
    Thanks-
    Jim
