barryamundson
Setting up Amazon Web Services Flash Media Interactive Server
Apr 24, 2011 5:17 PM
I've been trying to set up an instance of Flash Media Interactive Server on Amazon Web Services for an AVChat (avchat.net). I signed up for the service here: http://www.adobe.com/products/flashmediaserver/amazonwebservices/
I have some simple questions on getting it started --- namely: do I create the FMIS instance myself now that I've signed up, or do I need to go ahead and create it?
I see under the EC2 tab I can create an instance under 'Community AMIs'  for adobe-flashmediaserver-useast/fms-4.0.1.8011-centos-5.5-ami-1.manifes t.xml
Is this what I want? I realize this is a bit of a noob question.
once installed what I'm trying to do is to add a folder for AVChat into /opt/macromedia/fms/applications/ ( http://avchat.net/support/documentation/#21 ). I am assuming that once I do have this instance running, I can move/modify files on the server instance.
thanks,
barry
    Apr 25, 2011 6:37 AM   in reply to barryamundson
    I don't think you need to create any new instances, once you log in to the Amazon web services, as you mentioned , navigate to the EC2 AMIs where you should be able to see the manifests for already available instances for your service. Select and Launch Instance and configure for your purposes.
    Let me know if you need anything else.
    Thank you !
    Apr 26, 2011 1:12 AM   in reply to barryamundson
    Hi Barry,
    Sorry the link was down when you last tried it.  It worked for me so here's a sub link to the documentation for creating an account and setting up the server: http://help.adobe.com/en_US/flashmediaserver/amazonec2/WS6fc2df2b6d2ce 24359910e2812c396a83eb-7fff.html  Hopefully this will work for you.
    Once you have FMIS running, and is sounds like you already do, you'll need to log into your instance to add your FMS application.  The default application directory on the AMI is /mnt/applications.  FMS is installed at /opt/adobe/fms and you are free to configure it how you wish.  Here's a link for the "working with applications" documentation: http://help.adobe.com/en_US/flashmediaserver/amazonec2/WS6fc2df2b6d2ce 2431afba23c12c3967d3ca-7fed.html
    For ssh-ing to your instance, view the AWS documentation.  Log into your AWS account and go to the EC2 Dashboard.  Click Documentation under Related Links.  Select the Getting Started Guide, then the chapter Connecting to you Linux/Unix Instance.
    Kevin
    May 13, 2011 4:45 PM   in reply to Kevin.Lind
    I can find any of these AMI's
    http://kb2.adobe.com/cps/883/cpsid_88372.html
    What do i do then ??
    May 16, 2011 6:00 PM   in reply to DanelKirch
    Hi Barry,
    I'm not sure I fully understand your question.  In your previous posts, you mentioned that you were able to launch an instance of the adobe-flashmediaserver-useast/fms-4.0.1.8011-centos-5.5-ami-1.manifes t.xml AMI.  This is the FMIS AMI for AWS.  There is also a copy of this AMI on the Asia Pacific region with manifest adobe-flashmediaserver-apsoutheast/fms-4.0.1.8011-centos-5.5-ami-1.ma nifest.xml.  When you launch one of these AMIs, you choose one of 6 instance types supported by the AMI (outlined by the table in http://kb2.adobe.com/cps/883/cpsid_88372.html).  Once your instance has started, you can connect to the instance via SSH to configure FMS and upload custom applications.  Remember to open port 22 for SSH access in your instance's security group.
    Here's a link to the "Getting Started" documentation which outlines how to launch an instance of FMS: http://help.adobe.com/en_US/flashmediaserver/amazon/WS6fc2df2b6d2ce243 59910e2812c396a83eb-7fff.html
    Kevin
    May 31, 2012 9:20 AM   in reply to barryamundson
    None of the above links work. I am trying to login to my FMS 4.5 server on my new Adobe AMI instance and it is not letting me. I have modified the fms.ini and users.xml file but now luck. Can someone please help me? Also is there a seperate license key I need to enter in the fms.ini file?
    Cliff
    May 31, 2012 9:48 AM   in reply to netguru24us
    Hi Cliff,
    No there is no license/serial that you need to enter anywhere.
    Please elaborate on what issues you are facing.
    Meanwhile, all the documentation is here:
    http://help.adobe.com/en_US/flashmediaserver/amazonec2/index.html
    Shiven
