Move Tool does not move layer when dragging with Wacom tablet
Jan 14, 2013 5:01 PM
  Latest reply: Harpua42, Dec 13, 2013 10:25 AM
Replies 1 2 3 4 Previous Next
    Jan 6, 2011 3:05 PM   in reply to hirshmon
    Did you restart your machine first?
    Jan 6, 2011 3:19 PM   in reply to hirshmon
    It often happens while working with the stylus.  Often times when introducing and new text or internet image layer.
    Ash
    Jan 6, 2011 3:24 PM   in reply to hirshmon
    Don't worry -- I'm not saying that's the final solution or anything. I'm just trying to figure out the cause of the problem.
    Looking back at your description of your particular problem, you're unable to use the trackpad while a tablet is plugged in -- is this correct? This is another known issue that we're still working on. Unfortunately, I'm not aware of any current workarounds besides not using the trackpad or unplugging the tablet.
    So to reiterate, there are two possible tablet-related issues in this thread:
    1. Using the trackpad with a tablet plugged in.
    2. Starting Photoshop with the stylus or mouse in close proximity of the tablet.
    Jan 10, 2011 10:20 PM   in reply to Jeanne Rubbo
    I have the same problem when using Photoshop CS5 and my Intuos4 tablet. When I use my trackpad to move something it jumps back to the middle. the only way to move something is to use the Shift-arrow keys to move it 10px at a time or use the tablet.
    When I start up Photoshop my pen is 3 feet away from the tablet, so that's not the problem. I've tried unplugging the tablet and restarting Photoshop but the trackpad problem still happens.
    Any ideas what the heck the problem is? I've looked at Wacom's web site and can't find any mention of this issue, so I assume it's more of an Adobe issue. Does anyone have any more info on this issue? Links?
    Jan 12, 2011 1:05 PM   in reply to DavidDesign
    If you look at my last post, it sounds like you're running into the first of the two issues I listed. As I mentioned, we are aware of it and are looking into it, but for now I don't know of any workarounds (besides unplugging the tablet or not using the trackpad).
    Jan 20, 2011 8:44 AM   in reply to Jeanne Rubbo
    I'm having the issue now and I don't have the Wacom tablet with me at all. The wacom driver is installed and I have the latest PS patch.
    Feb 10, 2011 9:38 PM   in reply to hirshmon
    Just wanted to throw my hat in the ring... I'm having the same problem.  I also use a Wacom tablet but I brought my laptop hom
    e and started doing some work without the tablet attached and the move problem is happening... very frustrating!!  Please help.
    I do have the latest update 12.0.2 and using Snow Leopard... also have my older version of CS4 still on laptop as well.
    Let me know if you need anymore info.
    Mar 10, 2011 10:35 AM   in reply to hirshmon
    Hey everybody, if you're having this problem, check your menu bar items. I ran into this problem today and couldn't make heads or tails of it -- unplugged the tablet, quit Photoshop, restarted, reset settings, everything. Nothing worked. Then I remembered that I'd installed a new menu bar item (in my case, iCopy) since I'd last used Photoshop. I quit that program, and the issue completely went away. I'm guessing UI elements of certain menu items interfere with Photoshop, and I'm guessing iCopy isn't the only culprit.
    Mar 10, 2011 3:13 PM   in reply to billyokcom
    I've also seen this. Next time i will try the suggestion of quitting every other app running on the machine.
    Mar 10, 2011 3:17 PM   in reply to billyokcom
    Thanks for that info. For those of you on this forum who have noticed that the problem happens even after unplugging your tablet, are you running iCopy (or any other apps that may contribute to the problem)?
    Please let me know what you find out.
    Mar 10, 2011 3:19 PM   in reply to Jeanne Rubbo
    I do not have or run iCopy...  It seems to be irrelevant if I have background applications running or not.
    Mar 10, 2011 3:23 PM   in reply to TheFlash12345
    Same here no other apps
    Apr 6, 2011 10:10 AM   in reply to billyokcom
    thank you! i recently installed icopy and this started happening. been driving myself crazy trying to figure it out. so glad i came across this thread and your post.
    Apr 6, 2011 10:11 AM   in reply to Jeanne Rubbo
    yes, i just quit icopy and it resolved the issue.
    Apr 6, 2011 10:16 AM   in reply to Jeanne Rubbo
    there's a preference in icopy called "capture mouse drags" that appears to be causing this. when checked, it tries to copy any item you click and drag, system-wide. with this disabled, and icopy running, i am able to drag layers again.
    Apr 9, 2011 4:34 PM   in reply to hirshmon
    Just solved this problem! It's because of the wacom pen tablet driver i closed it in the activity monitor and the stupid snapback disapeared. down side is that the tablet won't work for obvious reasons i sugest we demand a solution from wacom on their forums.
    Apr 17, 2011 7:52 AM   in reply to hirshmon
    Same issue with me. I am on Mac OS with photoshop CS5 . The issue is due to iCopy app and disabling the drag mouse checkbox stopped this problem. Its big confusion.
    Apr 27, 2011 8:41 AM   in reply to hirshmon
    I echo this sentiment
    Apr 27, 2011 8:47 AM   in reply to TheFlash12345
    Hirshmon and The Flash, your issue is not related to iCopy? Do you have any other system utilities/drivers installed?
    Apr 27, 2011 8:56 AM   in reply to hirshmon
    We don't know of any specifics (other than we've seen iCopy cause this issue, and FinderPop cause others), but we do know this problem is system specific (i.e. not all customers are having this issue).
    Can you do a screen shot of your "System Preferences" dialog? Usually, they show up under "Other" in the bottom column.
    Apr 27, 2011 9:08 AM   in reply to hirshmon
    What is Candelair? It may be conflict between the Wacom driver and another driver or utility.
    Apr 27, 2011 9:28 AM   in reply to hirshmon
    I am also having the same issue but do nothave InCopy installed. For me the issue is that I have a Wacom tablet installed in my office. When I unplug and leave the office without rebooting I encounter this error. If I reboot without the Wacom plugged in, it does not occur.
    Attached is my system prefs screenshot also:
    Apr 27, 2011 10:40 AM   in reply to hirshmon
    Wouldn't hurt to try. Eliminating all possible culprits is a good approach.
    Apr 27, 2011 11:03 AM   in reply to Jeffrey Tranberry
    I do not have icopy installed or any other of the referenced programs that others are discussing, and I still have the problem.  Not to mention the only program that is affected is photoshop... my machine shouldn't be in the influencing factor if the only program affected is photoshop, regardless if some conflict exists somewhere in my machine.  If only photoshop is having troubles with a conflict, then it's my opinion that photoshop should resolve this conflict.
    Apr 27, 2011 11:45 AM   in reply to TheFlash12345
    No, that is bad logic.
    Bugs in the OS or other applications can cause problems that only seem to happen in a single application (it depends on the details of the bug). And they sometimes are such that the affected application cannot work around the original bug.  If we can work around external bugs, we do.
    Jun 10, 2011 12:21 AM   in reply to hirshmon
    I've been using CS5 with a Wacom Intuos 3 for a while with none of these issues, however today got a Cintiq and it started happening right away. A full reboot made it go away momentarily, but not for long. I'm getting the snapping issue as well as the brush not being able to draw with the trackpad.
    It's been almost a year since this problem came up, please fix this!
    Moving an object WILL work when you hit cmd+t and it's under Transform. It will also move an object when in a Mask.
    Jun 10, 2011 3:15 AM   in reply to hirshmon
    I use CS4, works perfectly
    Jun 10, 2011 11:46 PM   in reply to hirshmon
    I also have the problem. No iCopy or Candelair. But I do use an Intuos 4.
    Move tool snaps back and brush tools (brush, clone, eraser, etc) can only make dots, not paint continuous. I guess because the tool is also unable to move or is snapping back to place.
    I work with an external keboard, external monitor and the tablet, not using the trackpad.
    MacBook Pro
    10.6.7
    PS 12.04
    Latest Wacom Driver
    Topaz Detail
    Topaz Denoise
    Lightroom
    Firefox
    Safari
    Entourage
    Restarting PS gets a temporary fix.
    Jun 16, 2011 7:02 AM   in reply to hirshmon
    Exact same problem again here. Latest everything installed and no extras/plugins. I have an Intuos tablet though.
    The tablet and my magic mouse work fine - it's just the trackpad.
    This has to be a PS bug surely? Command-T transform works fine, as does dragging out a selection marque.
    Jul 29, 2011 3:31 PM   in reply to hirshmon
    I think the best option is moving by "Ctrl+t"
    Oct 4, 2011 9:46 AM   in reply to hirshmon
    I am still seeing this issue using Photoshop CS5 v12.0.4 x64 with the latest Wacom Bamboo driver v.5.2.5-3.
Actions
Bookmarked By (2)
