Preserving whitespace when importing an html String into a RichText
Apr 27, 2011 11:39 AM
Brief situation overview:
     The program allows the user to edit RichTextEditors and other classes in order to create presentable documents. The program handles printing the document so when the user wants a print preview or to actually print they select that option from the program's menu. Calling a print preview requests the printable data from all the elements in the document and puts them into formats that look more presentable (without editing controls).
Problem:
     When the RichTextEditor's htmltext is retrieved it gets imported into an instance of RichText but the whitespace gets collapsed.
Example:
This (in RTE):
     Table
     Key     Value
     1         2
     3         4
     5         6
Becomes (in RT):
     Table
     Key Value
     1 2
     3 4
     5 6
Relevant code:
     if(data is String) {
          var curElem:RichText = new RichText();
          var importer:ITextImporter = TextConverter.getImporter(TextConverter.TEXT_FIELD_HTML_FORMAT);
          curElem.textFlow = importer.importToFlow(data);
          //Some curElem.textFlow leaf color and baselineShift changes
          addToPage(curElem);
     } else ...
What I've tried/noticed:
     I have tried putting in
          XML.ignoreProcessingInstructions = false;
          XML.ignoreWhitespace = false;
          XML.prettyPrinting = false;
     and
          curElem.textFlow.whiteSpaceCollapse = WhiteSpaceCollapse.PRESERVE;
     before the importer.importToFlow() function gets called but it hasn't changed the results at all. Although changing the textFlow.whiteSpaceCollapse value wouldn't have done anything since the importer just creates a new textFlow (I thought I'd mention that I tried it anyway). When I tracked the values for XML that I changed during this process I made sure that they weren't getting reset to true at some point. Having said that I didn't do a depth step through the whole importToFlow() call so if it reset the values and changed them back (I don't know why it would do that) I probably wouldn't have noticed.
Sorry if I'm unclear about anything, if you need any more information then please let me know.
-Devin
    Apr 27, 2011 7:24 PM   in reply to Devin Warren
    Firstly, TLF now does not support *Table*. If you import an html string including <tr> <td>, those tags will be ignored and all the data in <td> and <tr> will be showed in one line.
    If you meet some other problems,  pls attach the html string you import.
    Apr 27, 2011 10:21 PM   in reply to Devin Warren
    It seems a bug. Let us double check it.
    May 2, 2011 6:47 PM   in reply to Devin Warren
    I have logged a bug of TEXT_FIELD_HTML_FORMAT importer.
    Thanks for your report.
    Jul 31, 2011 9:07 PM   in reply to Jin-Huang
    Pls make your code as follows, then the whitespace will be preserved.
    var format:TextLayoutFormat = new TextLayoutFormat();
    format.whiteSpaceCollapse = WhiteSpaceCollapse.PRESERVE;
    var config:Configuration = new Configuration();
    config.textFlowInitialFormat = format;
    var importer:ITextImporter = TextConverter.getImporter(TextConverter.TEXT_FIELD_HTML_FORMAT, config);
    var textFlow:TextFlow = importer.importToFlow(markup);
    Aug 12, 2011 1:06 AM   in reply to Jin-Huang
    Hello,
    This doesn't seem to work for me. I'm using the 4.1 SDK.
    My markup looks like: "       abc".
    Here are my settings:
    var format:TextLayoutFormat=new TextLayoutFormat();
    format.whiteSpaceCollapse=WhiteSpaceCollapse.PRESERVE;
    var config:Configuration=new Configuration();
    config.textFlowInitialFormat=format;
    var importer:ITextImporter=TextConverter.getImporter(TextConverter.TEXT_F IELD_HTML_FORMAT,config);
    But what gets shown is "abc".
    Aug 12, 2011 2:24 AM   in reply to BogdanMarian
    It works for me... I think you need at least TLF 2.0.0.232.
    Our fixes will only be in the new version.
    Aug 16, 2011 2:06 AM   in reply to Jin-Huang
    Sorry for the dumb question, but how do I find out what the exact version of my TLF is?
    Thank you.
    Aug 16, 2011 2:49 AM   in reply to BogdanMarian
    Have a look at \frameworks\rsls folder under the Flex SDK you are using.
    In SDK 4.5, there is a textLayout_2.0.0.232.swf. It means build 232 of TLF 2.0.
    PS:
    In some old threads of this forum, there are methods about how to replace TLF lib in Flex SDK.
    Apr 9, 2012 11:16 AM   in reply to Devin Warren
    this is the way to solve this bug and no need for changing any xml settings , simple and it works
    exporting the textflow:
    var richTextXML:xml = new XML("<"+"richTextXML"+"/>");
    richTextXML.appendChild(getCdataXMl());
    private function getCdataXMl():xml{
      var textFlowStr:String = TextConverter.export(textFlow,TextConverter.TEXT_FIELD_HTML_FORMAT
    , ConversionType.STRING_TYPE).toString();
    var textFlowXMl:xml = new XMl("<![CDATA["+textFlowStr+"]]>");
    return textFlowXMl;
    importing TextFlow from XMl :
    var htmlTextInStr:String = richTextXMl.text();
    var importtedTextFlow:TextFlow = TextConverter.importToFlow(htmlTextInStr,TextConverter.TEXT_FIELD_HTM L_FORMAT);
    textArea.textFlow = importtedTextFlow;
