Installation Encountered Errors
Apr 27, 2011 8:57 AM
Trying to install Adobe Drive 2.1, but the installation keeps failing.  I've tried restarting as recommended, but it makes no difference.  Looks like it is hiccuping on Microsoft_VC80_CRT_x86 payload.  Installer executed with "Run as admin...", as usual.
Here's the relevant software already on my system:
Windows 7 Pro x64
Web Premium CS5
Visual Studio 2008 Pro
Visual Studio 2010 Express
For details, here is the installation log from a failed attempt: Log File
Almost forgot to mention that the Installation Log Analyzer turned up no results.
    Apr 27, 2011 9:23 PM   in reply to merv_f
    Hi merv_f
    From the log you provided, it seems Microsoft_VC80_CRT_x86 payload installation failed, you can try to do the following steps:
    1) Go to payloads\Microsoft_VC80_CRT_x86 directory in the AD 2.1 installer path.
    2) Double click Microsoft_VC80_CRT_x86.msi to install it manullay, you can choose to remove it first from the prompt dialog, then install it, or repare it to make sure Microsoft_VC80_CRT_x86 is installed successfully.
    3) Relaunch AD 2.1 set-up exe.
    You can refer to the thread : http://forums.adobe.com/thread/664080?decorator=print&displayFullThrea d=true
    Any further problems, pls post here, thanks.
