When do surfaces get uploaded to VRAM / removed from VRAM?
Apr 27, 2011 2:58 AM
Hello! I'm aware of the differences of cacheAsBitmap and cacheAsBitmapMatrix and when to use them. However, can someone answer me the following questions?
1. If I set cacheAsBitmap=true - when does the DisplayObject get rendered into a bitmap? at the next screen update or when the object is next time actually visible on the stage?
2. same question for VRAM upload. If i set cacheAsBitmap=true - at what moment does the bitmap get uploaded to the GPU? right after it got rendered or only when it next time appears on the screen?
3. if I set cacheAsBitmap=false - does the texture get removed from VRAM instantly?
4. what happens if a DisplayObject that has cacheAsBitmap=true is set to visible=false. Will the texture persist in VRAM memory?
of course the questions apply when GPU rendering is used.
