chrise524
flexunit stage null reference
May 2, 2011 12:22 PM
I am trying to test some of my AS classes in flexunit.  Some of the methods reference the stage from components that are passed to it. When I set up the flexunit testing application I use the following code:
core = new FlexUnitCore();
core.visualDisplayRoot = this;
core.addListener( new UIListener( uiListener ));
However, I still get a null reference exception whenever the stage is referenced.  I was wonding if anyone knew what is going on or what I am doing wrong.
    May 2, 2011 12:55 PM   in reply to chrise524
    What is the object that 'this' refers to? Does that code exist on the main sprite, somewhere else?
    Glad to help just need a bit more info,
    Mike
    May 2, 2011 1:56 PM   in reply to chrise524
    Okay, a few things.
    If you are using Flex, you don't need to set the visualDisplayRoot. That is for ActionScript only projects.
    Second, display objects in Flash don't have access to the stage until they are on the display list. So, saying
    new Image() won't add that item to the display list.
    I am not sure what Control.initApp() does, but in one of your unit tests, they way you get something on the display list is to use the UIImpersonator:
    UIImpersonator.addChild( someImage );
    After that someImage would have access to the stage. However, bigger problem. Unit tests are about isolation and if you components need to get out to the stage or if Control.initApp() somehow adds the item directly to the display list you are going to continue to have different issues as you won't be able to keep things in isolation to test.
    Hope that clarifies a little bit,
    Mike
