Check out problem with InCopy / Alfresco
Mar 10, 2011 4:28 AM
I use the following components:
InCopy CS5 7.0.3
Drive 2.1.0.204
Alfresco 3.4.0 (d 3370)
Before I can start editing the text in InCopy, a dialog comes up and I have to check out the content
(Don't know the exact words of the dialog, because i only have a german version).
But when I try to check out the content, nothing happens.
The following error message appears in the log file 'CS5ServiceManager_java.log':
2011/03/10 11:56:24,326 [ConnectionHandler-kernel] ERROR GetAssetsHandler - asset not found: /.Trashes
2011/03/10 11:56:24,415 [ConnectionHandler-kernel] ERROR GetAssetsHandler - asset not found: /Testbereich/Ausgabe 03-09/om_dok Aufgaben/Text editieren.injb
2011/03/10 11:56:49,669 [ConnectionHandler-kernel] ERROR GetAssetsHandler - asset not found: /.Trashes
2011/03/10 11:56:49,731 [ConnectionHandler-kernel] ERROR GetAssetsHandler - asset not found: /Testbereich/Ausgabe 03-09/om_dok Aufgaben/Text editieren.injb
2011/03/10 11:56:53,524 [JobHandler-3] ERROR CheckOut - Caught exception
com.adobe.drive.data.model.DriveException: The assets are opened by point products.
at com.adobe.drive.internal.data.manager.DataManager.checkOperationIsAll owed(DataManager.java:7941)
at com.adobe.drive.internal.data.manager.DataManager.checkOperationIsAll owed(DataManager.java:7930)
at com.adobe.drive.internal.data.manager.DataManager.checkOut(DataManage r.java:3763)
at com.adobe.drive.internal.biz.versioncue.service.call.CheckOut.execute Item(CheckOut.java:93)
at com.adobe.drive.internal.biz.versioncue.service.call.CheckOut.execute Item(CheckOut.java:47)
at com.adobe.drive.internal.biz.versioncue.service.call.VersionCueCall$1 .run(VersionCueCall.java:125)
at com.adobe.drive.internal.biz.versioncue.service.call.VersionCueCall$1 .run(VersionCueCall.java:119)
at com.adobe.drive.data.internal.persistence.PersistenceRunner.run(Persi stenceRunner.java:119)
at com.adobe.drive.internal.biz.versioncue.service.call.VersionCueCall.e xecute(VersionCueCall.java:134)
at com.adobe.drive.internal.biz.versioncue.service.VersionCueService.che ckOut(VersionCueService.java:347)
at com.adobe.drive.ncomm.versioncue.CheckOut.handle(CheckOut.java:57)
at com.adobe.drive.ncomm.versioncue.VersionCueRequestHandler$1.run(Versi onCueRequestHandler.java:185)
at com.adobe.drive.core.internal.jobs.JobHandler$JobWrapper.run(JobHandl er.java:270)
at com.adobe.drive.core.internal.jobs.JobHandler$JobWrapper.run(JobHandl er.java:286)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExec utor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor .java:908)
at java.lang.Thread.run(Thread.java:680)
So my questions are
- what is a point product?
- what causes this error?
    Mar 18, 2011 5:03 AM   in reply to Snap-OM
    Adobe Drive 2.0/2.1 doesn't support InCopy officially, but we can try to reproduce the issue you reported. We can keep you update.
    Zhiqiang
    Apr 14, 2011 12:53 AM   in reply to Snap-OM
    Hello,
    Just give you update, it is an issue in AD side.  And we will fix it in Adobe Drive 2.2 , which will be released around July.
    Zhiqiang
    Apr 27, 2011 2:46 PM   in reply to Zhiqiang Liu
    Hi, Liu,
    I have the same problem, under following conditions:
    • Windows XP SP 3 (german) and - another place - Windows 7 (32 bit, german)
    • Adobe Drive 2.1.0.204, as a client from a VersionCueServer CS4, version 4.0.1.090
    • Adobe Bridge, opening an InCopy-File (*.icml) form here
    • Adobe InCopy CS4 (version 6.0.6), checkout from here does not work:
      InCopy-File is ever write-protected
    Is there any software-patch or workaround available, until Adobe Drive 2.2 is on the market?
    Thanks in advance for your answer, Yours sincerly Thomas Diedrich
    May 2, 2011 8:31 PM   in reply to Thomas Diedrich
    Hi Thomas,
    There is no direct workaround for your issue before Adobe Drive 2.2. You can check out the InCopy file via Bridge or Explorer, then you can copy this file to the local file system for editing. After that, you can copy back the file to the checked out file and check in it.
    Hope this helps.
    Zhiqiang
