Doesn't look like this is a compatible combination at the moment. Any word on an update for this library?
At the moment I've been getting an error saying "ReferenceError: Error #1069: Property _bindings not found..." on my SqlMap. whenever trying to run a query.
Can you please try the attached SWC?
I get the same errors, using the samples
using 0.9 I get:
Error #1069: Property _bindingsByDestination not found on com.adobe.cairngorm.persistence.sample.data.PersonSqlMap and there is no default value.
using 0.10 I get :
Error #1069: Property _bindingsBeginWithWord not found on com.adobe.cairngorm.persistence.sample.data.PersonSqlMap and there is no default value.
Always at the same place: ObjectUtil.as (l.62)
Any idea ?
From what I can tell so far it looks like the spicelib ClassInfo getProperties method is returning extra properties, more than just the grammar ones defined in sqlmap mxml files. Maybe other properties associated with setting up bindings when converting mxml files to actionscript? I don't know. I'm not too familiar with that area. I don't know if that's the desired feature of that method either. If so then the persistence library would need to change and if not then the spicefactory guys should know.
I just threw the following in for a quick fix at line 60 of the ObjectUtil class. It seems to be ok so far but not fully tested. all those extra properties had null values on the declaredBy property.
if(property.declaredBy == null)
continue;
Alex, I was able to reproduce the issue using the PersistenceTest project from svn, but given what I just said do you have any input on where I should be filing this.
Thank you ceas nyc,
This "fix" works for me... Not fully tested too, but I can temporaly let it like this...
I found nothing about this issue here : http://opensource.powerflasher.com/jira/secure/Dashboard.jspa
I just heard from Jens Halm (Spicelib) the below
One of the big changes for 2.4 was the support for the faster reflection provided by describeTypeJSON in Flash Players >= 10.1. So if there is a difference it is probably more likely a difference between describeTypeJSON and the old describeType. You can easily find out by running in Player 9 or 10.0 as Spicelib 2.4 falls back to using describeType then.
Regarding where to file this, you can do this direclty in our bugbase at https://bugs.adobe.com/jira/browse/cgm. Just Create Issue > Bug > prefix the title with Persistence and attach i.e. a patch to it if you have one. I know this is a bit of admin for you but it does allow us to manage this more effectively.
I created this bug in the bugbase following your instructions...but it's my first time in dealing with a bugbase, so I'm not sure my contribution follows the rules of this kind of tools.
https://bugs.adobe.com/jira/browse/CGM-73
Can you please tell me if I did the job correctly ?
I was having this exact same problem, with "Property _bindings not found ..." .
I'm today migrating from Flash Builder 4.0 to 4.5, and from Parsley 2.3.1 to 2.4.1. To fix the bindings problem I tried the persitence-0.10.swc, but that tells me my <ResultMap> constructs are unrecognized in my MyProjectSQLMap.mxml file. Specifically "Type was not found or was not a compile-time constant: ResultMap."
I suspect I was on such an old verison of the Persistence library that I may need to make major changes and reabsorb myself in understanding the persistence library again, which would be unwelcome at this point in my schedule. Or perhaps there is a different explanation for the ResultMap issue?
As an aside, I also went to get the persistence source thru svn, but the svn link is bad.
For this: svn checkout svn://svn.code.sf.net/adobe/cairngorm/code/trunk cairngorm-code
I get: svn: URL 'svn://svn.code.sf.net/adobe/cairngorm/code/trunk' doesn't exist
I believe Pascal worked on the persistence library recently.
I don't think it changed dramatically though.
version 0.10 is indeed the latest that was released.
The latest doc is here.
http://sourceforge.net/adobe/cairngorm/wiki/HowtoUsetheCairngormPersis tenceLibrary/
svn can be browsed here : http://sourceforge.net/adobe/cairngorm/code/839/tree/cairngorm3/trunk/ libraries/Persistence/
and the code checked-out from svn from here : http://svn.code.sf.net/adobe/cairngorm/code/cairngorm3/trunk/libraries /Persistence/
Don't hesitate to update our jira bugbase and send us patches if you feel like it.
Hello jpravetz2
Yes 0.10 is the latest release for the persistence API. I indeed made a few changes between 0.9 and 0.10 but nothing has changed dramaticaly as François stated. You shouldn't need to "reabsorb yourself to understand the library". It was only a few bug fixes and some minor enhancements.
Maybe you could send me some of your code so I can understand or, even better, reproduce your problem to track down the issue.
For info the persistence API is fully compatible with flex 4.5 and parsley 2.4.1.
Thanks François for the corrected svn links. Someone may wish to update the site with the correct information.
Pascal, the ResultMap and Result classes in com.adobe.cairngorm.persistence.api.grammar disappeared between the version of the Persistence library that I originaly used and what is in 0.10. This appears to have been replaced by newer syntax for inserting and updating entries. Looks like its time for me to reabsorb, and the PersistenceTest project looks like it will contain the help I need.
Thanks, Jim
François, at
The read only access svn link is slightly wrong
