Me again!! Not sure if this should go under Photoshop or Illustrator, but whenever I export an image to Photoshop it gets flattened and I can't do anything with it. I've checked and double checked that Write Layers, Max Editability etc is ticked but then I get a box saying "some containers in AI have been flattened". Advice in basic English please!!!
Illustrator tries to maintain the layers etc. It does not guarantee it will.
So it depends on what you have in your file. It would be nice to see the a screen shot of the file in PS with the layers panel
you might not want to show the whole image because of your copyright but you can place the layers panel on top of the image
so it obstructs part of it. Just show enough of it so we can tell what is going on.
You may have no choice in some cases except to copy and paste from PS to AI.
OK. I've attached a screenshot of the Photoshop window. Although the Layers Panel shows Layer1 + layer 2, I can't open them. Sorry if the screenshot is rubbish - it was my first ever attempt.
That's my problem. In Illustrator, I have 2 layers - each with their own groups, paths etc. but when I export the image to Photoshop the image gets flattened and all the layers become ONE uneditable layer. As in my original post, I have ensured that the boxes "Write Layers" and "Max Editability" are ticked, but then I get a window saying some containers have been flattened. I don't know why.
So let me get this correctly…you made a photoshop document with two layers, you copy one layer in Illustrator and you pasted it into Photoshop on ne of the layers and then you copied the other layer in Illustrator and pasted that in the second layer in Photoshop and they automatically merged?
Is that correct!
I have to admit I never heard of this happening before.
I'm puzzled.
No. I created an image with lots of layers in Illustrator and copied and pasted the whole thing into Photoshop, but instead of all the layers showing up in Photoshop I only get ONE merged layer which is uneditable. I get the same result when I Place or Export.
I read somewhere that this happens if you have lots of nested layers, but none of my layers are nested.
My reason for going from Illustrator to Photoshop is because I want to enhance the brightness and contrast on SOME of the layers in the image.
I think you are seeing two separate issues.
First, the illustrator is not exporting your layers because you have transparent elements. When it encounters transparency, it flattens everything below that object.
Second is if you are doing copy and paste between illustrator and photoshop: you need to paste as a smart object. If you don't have that as an option, your illustrator clipboard preferences might need changing [Illustrator:Preference…:File Handling and Clipboard:Set copy as to PDF].
You may want to copy and paste your layers individually to photoshop. It can help to have an extra (invisible) path to help align things in photoshop (just a rectangle at the top left can usually do it, or a frame around the whole thing).
Try that: Target each top layer and Enable KnockOut Group option in the transparency panel before exporting to PSD. You may also try the Isolate Blending option. Maybe this will allow you to export and preserve the top layer structure. But It might introduces some discrepancies between what you see in Illustrator and the exported PSD.
IF . . . you have a copy of Freehand MX, one way of retaining layers when exporting from AI (CS3) to PS (CS3) is:
Save Illustrator document as Illustrator 8 file.
Open exported .ai file in Freehand MX (you should see all your layers in the Freehand document).
Export from Freehand to Photoshop 5 format selecting "Include Layers" checkbox in Setup.
Voila.
I've tried your suggestion with the transparencies and Knockout Group but it still doesn't work. What Illustrator does is export the 1st 8 layers perfectly fine, then flattens the last 8 layers into 1 Photoshop layer. Is there a max # of layers when exporting to Photoshop from Illustrator?
I'm using CS4 and I can't remember ever having this problem with CS3.
Any help would be greatly appreciated.
Man, you guys are something else. Don't export the Illustator document to an open file in Photoshop. Just open Photoshop and hit open and select the name of the file in Illustrator you want to export to Illustrator. That's it. All layers should show up in Photoshop. Then do what ever you want with them.
