Eilmer
How do I get .cur cursor background to be transparent?
May 8, 2011 3:57 PM
I'm trying to create a cursor (meaning mouse pointer) in PS CS3. I downloaded this plug-in: FM91JHTXEYEYF7J6DB.8bi, and can save .cur files. They behave properly as mouse pointers, but the background is white, not transparent. I can save the same files as .gif or .png and the background is transparent. Any tips on what I should do?
-Stuart
    May 9, 2011 1:47 AM   in reply to Eilmer
    Try something like the following:
    1.  File>New  32px x 32 px 8 bit transparent RGB resolution 72
    2.  File>Place (I used a transparent pdf file for the cursor image)
        If you use the place command , uncheck antialias in the tool options bar.
        (if you don't have a transparent image, then select it and then New>Layer via Copy.
         so you can add the black background)
    3.   Ctrl click on the image layer to load a selection around the image, then go
          to Select>Inverse.
    4. Go to the channels palette and click the icon on the bottom that says
        Save Selection As Channel (makes a alpha 1 channel)
    5. Select>Deselect
    6. Fill the bottom layer with black and flatten the image.
    7. Convert to the index color mode Image>Mode>Index Color.
    8. Save as in the cursor format with alpha channels checked in the
        save as dialog.
    Cursor in action: (there is a shadow under the cursor, you just can't see it
                              in the screenshot)
    MTSTUNER
    Message was edited by: MTSTUNER
