AssetManagerException - Cannot search assets
May 10, 2011 9:27 PM
Hello,
I've come across a situation where I'm no longer able to use the Correspondence Solution Accelerator due to errors when trying to run an asset search.  I'm unsure how it happened, but now, whenever I log into the Manage Templates application, it fails when trying to retrieve the data dictionaries.  This happens for every type of user, including the super admin.
I thought that maybe running the Bootstrap might clean things up, but the same happens there as well.  The following is the output in the browser from the Bootstrap error:
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is com.adobe.icc.dbforms.exceptions.ICCException: ALC-DCT-002-007: AssetManagerException: {Code}-ALC-AMG-001-018 {Message}-Asset search failed because user is not authorized to execute a system search
     org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:656)
     org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
     javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
     javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
     org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:343)
     org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
     org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
     org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:355)
     org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:97)
     org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:100)
     org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:78)
     org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:54)
     org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:35)
     org.springframework.security.web.authentication.preauth.AbstractPreAuthenticatedProcessingFilter.doFilter(AbstractPreAuthenticatedProcessingFilter.java:89)
     org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:177)
     org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:188)
     org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
     org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:79)
     com.adobe.livecycle.usermanager.authentication.web.CSRFFilter.doFilter(CSRFFilter.java:52)
     org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:149)
     org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
     org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
     com.adobe.idp.um.auth.filter.SecurityFilter.doFilter(SecurityFilter.java:182)
     org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
root cause
     com.adobe.icc.ICCBootstrapper.doPost(ICCBootstrapper.java:126)
     com.adobe.icc.ICCBootstrapper.doGet(ICCBootstrapper.java:83)
     org.springframework.web.servlet.handler.SimpleServletHandlerAdapter.handle(SimpleServletHandlerAdapter.java:63)
     org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:771)
     org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:716)
     org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
root cause
     com.adobe.icc.bootstrap.AssetDefinitionsDeployer.bootstrap(AssetDefinitionsDeployer.java:65)
     com.adobe.icc.ICCBootstrapper.doPost(ICCBootstrapper.java:118)
root cause
com.adobe.dct.exception.DCTException: ALC-DCT-002-007: AssetManagerException: {Code}-ALC-AMG-001-018 {Message}-Asset search failed because user is not authorized to execute a system search
     com.adobe.dct.service.impl.DataDictionaryRegistryServiceImpl.searchDataDictionaries(DataDictionaryRegistryServiceImpl.java:375)
     com.adobe.dct.service.impl.DataDictionaryRegistryServiceImpl.getSystemDataDictionaries(DataDictionaryRegistryServiceImpl.java:534)
     sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
     sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
     java.lang.reflect.Method.invoke(Unknown Source)
     org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
     org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
     org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
     org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:67)
     org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
     org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
     $Proxy560.getSystemDataDictionaries(Unknown Source)
     com.adobe.icc.bootstrap.AssetDefinitionsDeployer.bootstrap(AssetDefinitionsDeployer.java:61)
note The full stack trace of the root cause is available in the JBossWeb/2.0.0.GA logs.
So I've tried rebotting the server, running the Bootstrap, checking the permissions in the LC Admin etc, but no luck.
Does anyone have a clue why this has happened and how it might be fixed?  As it is right now, I can't use the SA at all!!!
Kristian
    May 11, 2011 12:07 AM   in reply to Kristian Wright
    Did you change any permissions in and around CM?
    Could you please provide details on what was done on the system before you hit this issue?
    May 11, 2011 5:12 AM   in reply to Kristian Wright
    The user with  you are bootstrapping with should be part of the group (directly) "System Data Dictionary Administrator" and domain "DefaultDom".
    Could you check what does the group "System Data Dictionary Administrator" show as its "Child Principals"?
    May 11, 2011 6:30 AM   in reply to Kristian Wright
    Are there any customizations done on the solution?
    I am specifically interested if there are any changes done to the file security-es-config.xml? If possible, could you share what's in that XML on the deployed EAR?
    May 11, 2011 8:44 PM   in reply to Kristian Wright
    Indeed there would be an issue if you have logged on to multiple LC applications with different users, courtesy SSO. It may very well happen that the bootsrap is executed using a non-privileged user (clopez or someone else in your case).
    Try doing the following:
    1. Close all browser sessions
    2. Open an all new browser session
    3. Login to CMSA portal (http://<host>:<port>/cmsa/ClaimsPortal/pages/HomePage.jsp) as "administrator"
         Note: If you are running/bootstrapping CMSA for the first time, you will not be able to logon using this URL. So, the other way round is to login to Contentspace (http://<host>:<port>/contentspace) using "administrator". [but I don't think that's the case for you]
    4. Now Bootstrap CMSA through http:<host>:<port>/cmsa/Bootstrap
    5. You should see a bootstrap successful message when complete.
    Once you are done with the above, it is recommended that you close the existing browser session and then log into CMSA using the desired user in a new session.
    May 12, 2011 12:22 AM   in reply to Kristian Wright
    Kristian,
    Looks like the underlying System user looses the membership to the group "System Data Dictionary Administrator" after following these steps. Will investigate the reason for this, and get back to you.
    May 16, 2011 3:00 AM   in reply to Kristian Wright
    Hi Kristian,
    Try bootstrapping with the option 'createSampleUsers=true'. This is what your boostrap URL would hence look like - http://<host>:<port>/cmsa/Bootstrap?createSampleUsers=true
    This should resolve your issue. Let us know...
    May 16, 2011 6:45 AM   in reply to Kristian Wright
    Good to know that you're all set now!
    The most probable reason for this is that when you change permissions, the same needs to be sync'ed over to CS as well. And if that does not happen due to some reason, then you may see issues. A bootstrap with the above options ensures that users and groups are creaeted and in sync.
