SteveC100
CSS for Book Document in 5.5
May 9, 2011 9:31 PM
I believe I've just found another glaring problem with the epub implementation in CS5.5.
I have a 20 chapter book. Created with very consistent styles for everything and using a book file to keep all styles synchronized.
But when I create the epub -- I get a new set of styles for every chapter. One CSS style sheet doc. But 20 copies of every style. Body-Text, Body-Text-1, Body-Text-2, etc.
Just to be sure I wasn't causing this, I just resynched all paragraph styles. No change.
This takes away a whole lot of the value of styles. Now if I want to edit the CSS I have to edit every entry 20 times. This is nuts.
Is there a place where I should be complaining about this? (The other glaring error I'd love to talk about is the way images are handled. Adobe insists on creating height/width descriptors based on a 72 dpi screen (which doesn't exist anymore) rather than the pixel dimensions of the image -- which is what all ereaders expect. Absolute dimensions ought to be an option, at least.)
I was very optimistic about this version of ID. But the deeper I get into it the more disappointed I am.
Thanks to anybody who can help --
Steve
    Community Member
    May 10, 2011 3:47 AM
    Yes I had that as well. But unfortunatly I haven't found the time to go into more with testing. If that IS a bug, its a massive problem
    These and other reasons are why I still make epubs using CS3. (200 epubs and counting )
    Community Professional
    May 10, 2011 5:38 AM
    The place to report bugs is here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    That said, what happens if you just assign an already existing CSS file?
    Bob
    May 10, 2011 8:55 AM
    Why don't you just map the p tag to those styles and then create a CSS rule for the p tag?
    Bob
    May 10, 2011 10:25 AM
    New to CS5.5 is the ability to map any paragraph style to any HTML tag.
    Once you've done that it's a simple matter of defining the tag in the CSS.
    Bob
    May 10, 2011 10:50 AM
    You won't get any of that if you don't specify classes when you export. It's way cleaner that way but you have to be able to write your own CSS.
    Bob
    May 10, 2011 11:28 AM
    You could be losing some manual overrides, but other than that, I don't know.
    Bob
    Community Member
    May 10, 2011 3:51 PM
    Gaaaaa...
    If this really is the case, (because I havn't tested it yet) There is no way in hell I want to go and map style names to tag name, (does Adobe not understand how many that could be) That's insane the amount of time I'm going to spend on that task when it was working just fine thank you in every other edition...
    I'm off to test and retest...if this really is the case, does Adobe offer refunds, as this is a deal breaker...
    May 10, 2011 4:11 PM
    30 day money back policy, but if you simply open the Paragraph Styles menu you'll find a command called Edit All Export Tags. Shouldn't take you but a couple of minutes to do every style.
    Bob
    Community Member
    May 11, 2011 8:10 AM
    You can do them all together without opening the styles definition at all:
    1. Go to the paragraph style panel or to the character style panel
    2. In the panel menu > Edit akk Export Tags…
    Here you find a list of all Paragraph styles and you can edit all export tags in only one step. This done in one document lets synchronize the whole book.
    May 11, 2011 1:45 PM
    I will ask what I asked before (since I don't remember the answer). Have these documents been edited in CS5 or CS5.5 before synching? If not, I'm not so sure this a bug as it is the text reflowing because of the difference in text engines.
    Bob
    May 11, 2011 3:58 PM
    Very strange behavior. I wish I had an explanation for you.
    Bob
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
