jfweber
Access Modifiers - strange behavior (public does not work but protected does) - why?
May 13, 2011 2:13 AM
I encountered some unexpected behavior for theaccess modifiers I cannot explain; maybe someone can help me out:
There are two classes:
"Player" und "Table" - both inherit from the same class and are located in the same package in the same directory.
"Player" wants to call function "deletePlayer" in "Table" but this seems to only work when I have the access modifier set to "protected" - if the function "deletePlayer" is public I receive an error:
Player.as, Line 34     1118: Implicit coercion of a value with static type modules.room:Player to a possibly unrelated type Player.
Why does public not work?
public class Player extends UIObject
        private var table                    : Table;
        public function Player()
        public override function init($table : MovieClip) : void
            table = Table($table);
        public function deletePlayer() : void
            table.deltePlayer(this);       // This calls the function in Table
            delete this;
package modules.room
    import flash.display.MovieClip;
    import flash.events.MouseEvent;
    import modules.room.Room;
    import modules.room.Player;
    import modules.UIObject;
    public class Table extends UIObject
        private var players             : Array = new Array();
        private var timer                : Timer;
        private var room                : Room;
        public function Table()
        public override function init($room : MovieClip) : void
            trace("init Table" + $room);
            room = Room($room);
            initBtnCreateTable();
        private function initBtnCreateTable() : void
            btnCreatePlayer.addEventListener(MouseEvent.CLICK, createPlayer);
        public function createPlayer($event : MouseEvent) : Player
            trace("creating player");
            var player : Player = Player(addChild(new Player()));
            players.push(player);
            player.name = "Player" + players[players.length - 1];
            player.init(this);
            return player;
        public function deltePlayer($player : Player) : void          // This will throw an error until I set access modifier to protected
            for (var i : int = 0; i < players.length; i++)
                if (players[i] == $player)
                    players.splice(i, 1);
                    trace(players);
    May 13, 2011 6:33 AM   in reply to jfweber
      If you are using Flash IDE, search in Library for symbols that has defined Class property as "Player" or "Table" and change to something different, for example "_Player" and "_Table". Setting deletePlayer() to protected may cause RTE.
