i kept a button visible after a target hit & its hidden on page load. but on device it loads on page and the other hiding button doesnt work. and also with videos, it just simply shows up like an image. nothing happens though i can see it on InDesign preview.
please help!
Sounds like you have an issue with how you set up your "overlays" .. remember they are OVERlays meaning when the folio is rendered overlay content will automatically go above regular content.
Sidenote-- multi-state buttons are not supported and buttons can only have one action. There are workarounds to this method I suggest reading Bob Bringhurst tutorial on hotspot buttons: http://blogs.adobe.com/indesigndocs/2010/12/hot-spot-button-workaround -for-indesign-dig-pubs.html
Remember to keep your "hidden" or hotspot buttons on top of your layer stack to ensure they remain on the top overlay when the folio is rendered.
As far as your video content.. double check to make sure it is rendered in the appropriate codec... maybe share your settings inside overlay creator.. and an image of your issue.
Best regards
David
No problem. Let me know if you need anymore help. I find with "buttons" the best way to image it is as if your making webcontent. You have the graphic representation for your button then you have the hotspot over it.
Here is a list of features that are and are not supported:
InDesign CS5 includes many interactivity features for exporting to SWF and PDF. Some but not all of these features are supported in the digital publishing workflow.
Supported hyperlink actions include Go To Destination, Go To First Page, Go To Last Page, Go To URL, Go To Page, Go To State, Go To Previous State, and Go To Next State.
buttons done perfectly! thanks again. i wish they add multitasking button feature in later versions. could save a lot of time
now, need help again lol. i imported a video and with any preset i apply, it just shows a bar(which cant be manually navigated) and play button. how can i show full-screen vids? i already set that to play on full screen.
1 more problem, InDesign cant import images for 360 viewer. i've set images name *001.jpg *002.jpg as shown but just 1 image imports from the folder. do you know a solution?
thanks
Are you using the pre-release drop 11? or the final Digital Publishing Suite tools?
360 was changed to "image sequence". When i do mine personally i start with 0000.jpg so "myimage_0000.jpg, myimage_0001.jpg" and so on. Remember to have these images in a seperate folder and link it from within the overlay creator tools.
For your video: In the pre-release you had to make sure "play inline" was uncheck.. in the final DPS tools inline was automatic unless you check "play full screen" .. so when you tap the "poster image" or button for your video (if the "play full screen" is check) it should automatically go full screen with a nav bar and close button. Try saving your file making sure the "play full screen" box is checked.. and preview it again.
iGizmo and Reader's Digest have done perfectly :S
anyway, i was getting the same message 'no internet connection' on pc content viewer as well. this is because i moved html fla files away from contents. so i retored them and its working again. well, the final export of folio to my accont doesnt upload these files & it shows a round loading bar as seen on flash contents on web.
how can i upload fla files to folio? how can i make them work?
haha no i havent tested on iPad yet. So you mean all i've done is perfectly fine on myside?...but i dont think so.
see, the html file ive imported into indd will anyhow look for fla which is in html5(embedded). and when indesign makes a folio, it wont export any others than '.indd' itself. how can a tablet display fla content?
that was a refresh! yeah HTML5 doesnt need flash. thanks again for support you guys. really apprecieate. i think i'll test on iPads with this issue.
one last Q: why doesn't adobe content reader shows up html5 when i move embedded fla contents away from directory? it shows the same "loading" icon spinning... i dont get it
Hi David,
I was readig your answers, but anyway I couldn't make may movie magazine cover work.
What I need, is to make some areas of the cover sensible (buttons), to direct to each article inside it.
Here's the problem:
1) I created a movie as the cover of a magazine, with Premiere
2) At the end of the movie, i need to make sensible some areas (topics of the magazine)
2) Used de mp4 format to build it
3) Created buttons and put them over the movie
4) Tried to use buttons in different layers
They don't work!
What I'm doing wrong?
Thanks for your help!
Claudir
