Invalid Configuration Location error on startup
May 17, 2011 12:20 PM
I have just installed Flash Builder 4.5 on my Windows 7 Enterprise edition. I installed this using my username (not Administrator), which has local administrative rights. When I start the program, I'm getting the error
The configuration area at 'C:\Users\Administrator\Adobe Flash Builder 4.5\cascaded\308971\configuration' could not be created.  Please choose a writable location using the '-configuration' command line option.
OK
Any reason for this error and what's the workaround?
    May 18, 2011 8:04 AM   in reply to DCAKen
    Looks as if the eclipse/fb launch configuration is confused about which account to use on that machine. That path should be under your own profile as c:\Users\yourUserName\etc...
    Here are some things you could try:
    - launch FB 4.5 with the "Run as Administrator" option, by right-clicking the exe or the shortcut for it.
    - if that avoids the error, make sure it doesn't return after quitting and re-launching without "Run as administrator"
    Let us know what happens with that, and we can make further adjustments if needed.
    -Chris
    Nov 14, 2011 9:50 AM   in reply to DCAKen
    I am getting the same problem in OSX Lion.
    Any idea on how to fix on a Mac?
    Thank you
    Jan 24, 2012 12:30 PM   in reply to edwinmerced
    Had the same problem in OSX. Used finder to go to the folder it was referring to. Opened the file info panel. Set the permissions to read and write.
    Sep 5, 2012 10:35 AM   in reply to DCAKen
    Hey there!
    Found a woraround to your problem...
    Go to your Flash Bulder install directory and then navigate to the eclipse folder (something like <FB_install_dir>\eclipse\...)
    There you will find a config file with the following lines (at the end of the file):
    osgi.configuration.area=@user.home/Documents/Adobe Flash Builder 4.5/cascaded/<build_number>/configuration
    osgi.shared.configuration.area=file\:configuration
    osgi.configuration.cascaded=true
    What you do is simply remove them. Afterwords when you start the Flash Builder again you will be prompted to enter a new directory to your workspace and everything will run smothly after that.
    Cheers!
