Is this possible?
How do I do this?
You should be able to without issue, find the 'Installed Flex SDKs' settings in the Preferences window and add the 4.5 SDK there. After adding your new SDK either check the box next to 4.5 to make it the default or to change it per project you need to go to the project settings and change the 'ActionScript Compiler' settings to 'Use a specific SDK' and select the new SDK.
I also recently tried switching from SDK 4.1 to 4.5, the issue I have is when running the debugger it prompts an error saying "Required Adobe Flash Player version not installed" . Is there a way to set the path to the FlashPlayerDebugger.exe in FlashBuilder? Or are we forced to run the installer each time we want to debug against a specific version?
Okay guys i'm sorry but is there a free upgrade to Flash Builder. My Flash Builder says version 4.0.1 (build 277662) Is there a way to upgrade this without a cost to me?
I just purchased the Master Collection and shortly after they released 4.0.1.
fb4.5 should come along with master collection 5.5 call sales.
I'm having issues using 4.5 in FB 4.0
Every time I create a new project and target 4.5 I get the following errors:
Description | Resource | Path | Location | Type |
1084: Syntax error: expecting rightbrace before css | testing | Line 24 | Flex Problem | |
1084: Syntax error: expecting rightbrace before end of program | testing | Line 447 | Flex Problem | |
1084: Syntax error: expecting rightbrace before s | testing | Line 24 | Flex Problem | |
1093: Syntax error. | testing | Line 24 | Flex Problem | |
1093: Syntax error: A string literal must be terminated before the line break | testing | Line 24 | Flex Problem |
keep in mind the is a new project targeting the 4.5 SDK in Flash Builder 4.0. I have done nothing but create the project.
If I create the project with 4.1 SDK in Flash Builder 4.0, there are no issues.
Can someone confirm this is an issue with using 4.5 in FB 4.0 or share a solution to resolving the issues?
Thank you.
I know this is after a long time...but can anyone confirm if we can use the 4.5 SDK or 4.5.1 SDK with Flash Builder 4 ? without any problems ?
Will the Flash Builder 4.0.1 update help ? Or if there 'is' some problem with using FB4 with SDK 4.5 then is there some kind of update patch for this ?
I actually switched to IntelliJ and haven't looked back.
