I have just installed Flash Builder 4.5 on my Windows 7 Enterprise edition. I installed this using my username (not Administrator), which has local administrative rights. When I start the program, I'm getting the error
Invalid Configuration Location
The configuration area at 'C:\Users\Administrator\Adobe Flash Builder 4.5\cascaded\308971\configuration' could not be created. Please choose a writable location using the '-configuration' command line option.
OK
Any reason for this error and what's the workaround?
Looks as if the eclipse/fb launch configuration is confused about which account to use on that machine. That path should be under your own profile as c:\Users\yourUserName\etc...
Here are some things you could try:
- launch FB 4.5 with the "Run as Administrator" option, by right-clicking the exe or the shortcut for it.
- if that avoids the error, make sure it doesn't return after quitting and re-launching without "Run as administrator"
Let us know what happens with that, and we can make further adjustments if needed.
-Chris
I can start it using "Run as Adminstrator", but then I can't access a drive that has been mapped to my user name. After I have sucessfully started it using "Run as Adminstrator", starting it normally gives me the same error pointing to the C:\Users\Administrator\... directory.
I am getting the same problem in OSX Lion.
Any idea on how to fix on a Mac?
Thank you
Had the same problem in OSX. Used finder to go to the folder it was referring to. Opened the file info panel. Set the permissions to read and write.
Hey there!
Found a woraround to your problem...
Go to your Flash Bulder install directory and then navigate to the eclipse folder (something like <FB_install_dir>\eclipse\...)
There you will find a config file with the following lines (at the end of the file):
osgi.configuration.area=@user.home/Documents/Adobe Flash Builder 4.5/cascaded/<build_number>/configuration
osgi.shared.configuration.area=file\:configuration
osgi.configuration.cascaded=true
What you do is simply remove them. Afterwords when you start the Flash Builder again you will be prompted to enter a new directory to your workspace and everything will run smothly after that.
Cheers!
This worked perfectly. Thank you!!
