clarkhad
Image Sequence question
May 18, 2011 9:39 AM
I created an Image Sequence in InDesign by bringing in about 50 .png files. I want to show the first image in the sequence when the page loads, so I checked "Show First Image Initially". I'm assuming that this makes the first image a "poster".
The problem is that when I view my app in the Adobe Content Viewer and swipe through my images, the poster image shows up under my spinning object throughout the spin. I thought that it should disappear so that I can spin my object 360º without seeing the poster image underneath. How can I get the poster image to disappear when I swipe through my object?
  • Bob Bringhurst
    May 29, 2007
    May 18, 2011 10:01 AM   in reply to clarkhad
    Create a poster image that's the same size as the Image Sequence, but don't include it in the folder with the rest of the images. Place the poster image, select it, and create the Image Sequence overlay. Uncheck Show First Image Initially.
  • Bob Bringhurst
    May 29, 2007
    May 18, 2011 12:07 PM   in reply to clarkhad
    Yes, your poster is showing through the transparent background. Let me ask around to see if there's a workaround for posters with transparent overlays.
  • Bob Bringhurst
    May 29, 2007
    Jun 1, 2011 9:18 AM   in reply to clarkhad
    No, I haven't been able to figure out a way to include a poster with transparent images in an Image Sequence.
    Feb 23, 2012 2:21 PM   in reply to Bob Bringhurst
    Bob,
    The problem of the initial image still displaying behind an image sequence with alpha still hasn't been resolved.  Will this ever happen?
    Also, when unchecking "Show First Image Initially" and choosing "Auto Play" an image sequence with alpha looks fine when viewing the article, however the thumbnail images in the browse mode and the table of contents do not show any image from the sequence, therefore looking like a big empty space.  Is there a workaround for this?
    Andrew
    Feb 23, 2012 2:52 PM   in reply to Andrew Smith
    Another bit of strangeness with image sequences: autoplaying shows the counter-clockwise rotation of my original rendered images, however when tapped once to stop and then tapped again to continue playing the image sequence the rotation is now clockwise (the reverse of the original direction).  This isn't a huge deal but it is odd. Double-tapping to reset the sequence makes the image disappear when "Show First Image Initially" is unchecked.
  • Bob Bringhurst
    May 29, 2007
    Mar 7, 2012 8:19 AM   in reply to Andrew Smith
    What image format are you using for your image sequence files?
    Feb 24, 2012 1:40 AM   in reply to clarkhad
    I've been reading through the forums about transparent PNG image sequences and wondered if there is a fix yet so that the poster image does not display behind the image sequence? Thanks.
    Feb 24, 2012 7:28 AM   in reply to Bob Bringhurst
    Bob,
    I'm using After Effects to render out an RGB+Alpha PNG sequence.
    Andrew
    Mar 7, 2012 9:36 AM   in reply to clarkhad
    Has anyone found a solution to this issue yet? I'm having the same problem and have tried the same suggestions with no results. JPG files work fine. PNG are preferable though because of the transparent background. The image sequence itself works, but the poster image will not disappear and the sequence rotates over it. Or the poster image will not show at all.
    Thanks for any help!
    John
    Mar 7, 2012 12:08 PM   in reply to Andrew Smith
    Hey Andrew -
    You can upload a custom thumbnail for the page in question - I do that for pages that contain big areas of HTML content.
    Mar 7, 2012 12:52 PM   in reply to mdc1313
    mdc1313,
    I can see where to change the Table of Contents thumbnail, but I'm wanting to be able to change the tall "thumbnail" displayed in the browse mode where you can see the top part of the whole stack and the articles in relation to each other.  Do you know of a way to change this preview image?
    Andrew
    Mar 7, 2012 1:08 PM   in reply to Andrew Smith
    Andrew, you do this in the online Folio Producer-Organizer. In the Folio Producer, select the folio containing the article in question. Click the "Open" button at top. Scroll until you find your article, and click to select it. In the info box at left, on the bottom is a link that allows you to upload a custom TOC image.
  • Tomek Kuczborski
    Nov 23, 2006
    Mar 7, 2012 1:38 PM   in reply to Andrew Smith
    AFAIK you can't do it without disassembling the .folio and manually replacing images there.
    Apr 28, 2012 10:04 AM   in reply to Bob Bringhurst
    This is a follow up to an old problem/fix request...
    I was hoping V19 producer tools may have fixed the transparent PNG sequence issue where it leaves the inital image behind the rest of the images.
    Has anyone found a fix to this yet?
    Thanks.
    Apr 30, 2012 12:20 AM   in reply to Bob Bringhurst
    Hi all
    and this is another follow up to the PNG sequence issue with the initial image showing up!
    I can not figure out why the bug is still here in v19 ?
    Regards.
    Aug 10, 2012 3:37 AM   in reply to ellipsis81_uk
    Hello,
    I have struggled with this today, so this bug seems to be there still. I upgraded to last version today, prior to start working.
    Seems as I need to go back to jpgs to make this work..
    Thanks.
    Aug 10, 2012 8:18 AM   in reply to box@globalmaritime
    One way around this is to make an MSO with the first state being the first frame of your PNG sequence and the second state being the image sequence.  You set the MSO to autoplay with a short interval (0.125 secs), tell it to play 1 time and to stop at the last image.  If you want to edit the image sequence settings once you've put it into the MSO just select the state in the object states panel and double-click on the image sequence.  Image sequence options such as "Swipe to Change Image" should work normally.
    Andrew
