I am new to Illustrator, and have problem drawing these shapes in 16px by 16px:
As you can see below, the shapes for both plus and diamond are not in best quality. especially the line looks dotted and gray.
Below is information for each shape:
1) square: 1 px border in black, white colour within the area of the square.
2) diamond: 1 px border in black, white colour within the area of the diamond, the rest is transparent.
3)plus sign, 1 px border in black, white colour within the area of the diamond, about 2 pixels wide for the white area, the rest is transparent.
Could anyone help me with this. It would be very much appreciated If a illustrator file can be provided (via sendspace.com). Ideally, when it is zoomed in to 120%, the shape does NOT blur.
Thanks in advance!!!
Kingofwebguru,
Simple ways with simple means (to require less effort (including learning) may be, using the Rectangle Tool:
1) Create a rectangle with width and height as one of the two that forms the cross, copy it, Object>Transform>Rotate the copy 90 degrees, select both, and Pathfinder>Unite;
2) Create a rectangle and Object>Transform>Rotate it 45 degrees;
3) Create a rectangle.
Apply stroke weight and colour(s) as desired.
Kingofwebguru wrote:
... Ideally, when it is zoomed in to 120%, the shape does NOT blur.
That's not going to happen.
Slanted lines will always be drawn blurred in Illustrator, because your screen pixels form a rectangular grid. Only if you export to a bitmap file, you can "remove" any blurriness, but at the expense of the overall visual quality.
Read this part of the manual
http://help.adobe.com/en_US/illustrator/cs/using/WS714a382cdf7d304e7e0 7d0100196cbc5f-636da.html
This Adobe Illustrator tutorial is very helpful. I have added this tutorial on: http://illustrator-tutorials.co.cc/illustrator-tutorials/how-to-draw-t hese-shapes-square-diamond-plus-sign/
Thank you!
