MedInv
Premiere Pro Error: Time.cpp-209
Sep 24, 2009 12:07 AM
Hello,
I need some help for Adobe Premiere Pro CS4.
Yesterday I installed the trial Version.
If I import a video file there comes the following error message:
Premiere Pro Debug Event
Premiere Pro has encountered an error.
[..\..\Src\Time.cpp-209]
Do you now where is the Problem?
What can I do?
MedInv
    Sep 24, 2009 12:34 AM   in reply to MedInv
    Your source material.
    Sep 24, 2009 7:23 AM   in reply to MedInv
    First, work through all of the steps here http://ppro.wikia.com/wiki/Troubleshooting
    If your problem isn't fixed after you follow all of the steps, report back with the DETAILS asked for in the questions at the end of that link
    Sep 24, 2009 2:34 PM   in reply to MedInv
    Per Harm's reply, tell us all about your source material. It is likely the cause of your problem.
    Good luck,
    Hunt
    Sep 25, 2009 9:10 AM   in reply to MedInv
    The fact that you're "importing" suggests one of two things.  First, you're not a professional editor, but just a guy (or gal) who has a downloaded or ripped video they want to edit.  If this is the case, I recommend using consumer software.  You'll have better luck.
    Second, you may well have some clue about video editing, but are tying to use media from an AVCHD or XDCAM EX camera.  In which case, the trial does not support anything MPEG for licensing reasons.  You'll have to test with DV, or purchase the program to get full support.
    Oct 11, 2009 6:29 PM   in reply to Jim Simon
    I have also had exactly the same problem with fully licensed and updated software.
    I also get it previewing or importing a wav file produced by the default settings of Windows XP Sound recorder.
    then it crashes the whole product.
    This is certainly not a very graceful way for a supposedly professional application to fail to import or preview something.
    I have not had anything like these problems with any other Adobe product - including earlier versions of Premiere.
    Oct 11, 2009 11:55 PM   in reply to Geematic
    A supposedly professional application requires supposedly professional video material from a video camera.
    Feb 25, 2010 2:17 AM   in reply to Harm Millaard
    I got a licensed and fully updated version of Premiere Pro CS4 (4.2.1). We recorded some audio in an older version of Premiere Pro 2.0 on another PC, because i'm running Windows 7 and my PreSonus Firebox isn't working on it. We recorded in wav format. When importing the audio, Premiere Pro CS4 gives an error [..\Time.cpp-209] and shuts down. Some help would be great!
    Feb 25, 2010 3:09 AM   in reply to MvBriemen
    Try deleting any Premiere cache files associated with the .wav file.  They have file extensions like .pek, .cfa, .xmp, .xmpses and have the same name as the .wav file.  Make sure to delete both 2.0 and CS4 cache files.  They may be in different locations.
    Did you add any metadata to the .wav file when you exported it?  Did you change the timecode or sample rate?  Have you processed it in any other application besides Premiere between then and now?
    -Jeff
    Feb 25, 2010 7:01 AM   in reply to Jeff Bellune
    Also, what are the Sample-rate and Bit-depth of the WAV file - 48KHz 16-bit? Also, is it PCM/WAV (uncompressed)?
    Good luck,
    Hunt
    Feb 25, 2010 2:25 PM   in reply to Bill Hunt
    Ditto for Bill's question.  What are format specifics of the file?
    Also, are you importing the wave file into a new project, or are you trying to import an old project that's referencing that file?
    (The time - 209 error msg you're referencing pertains to doing a time alignment operation with a framerate of zero, which is illegal.  I've never seen this happen with importing audio files, but I have seen things like this when loading older projects that have some kind of data corruption.)
    Cheers
    Feb 25, 2010 2:35 PM   in reply to MedInv
    Are you by any chance using Cineform? The two times I have experienced that error, one was Cineform related, the other was Quicktime related.
    Matthew
    May 19, 2011 3:26 AM   in reply to MedInv
    Hey all,
    I'd like to dust this off as I'm hitting the same issues, I wonder if any progress has been made so far?
    I can reproduce the bug from several different audio sources, including extracting audio tracks from video.  But we'll concentrate on the simplest form now to help debug.  I'm importing a wav file, either windows generated or VLC (ffmpeg) extracted, it is PCM, stereo, 16 bit and 48kHz sample rate.  I can import it into any project new or old & I've tried clobbering the "My Documents\Adobe\Premiere Pro" directory.
    Possibly related, but if I try and import an mp3 version of this track I get an "Error compiling movie.  Unknown error." message, after which the file does appear in the project but won't output any sound.
    It seems in fact that the only way I'm able to get Premiere to output sound is by creating a "Bars & Tone" object, I've tried a host of other audio formats which all either crash or error.  Sort of suggests to me that it's not so much related to the content, but as the Bars & Tone track plays I'm not sure what to do.
    James
    May 19, 2011 7:37 AM   in reply to MedInv
    OK we have found a workaround, which I'll put here for others that may hit the same issue.  In the lab here we map some standard windows directories to network drives along with our user accounts.  This includes things like "My Documents" and some temporary windows caching directories.  Other than the bug I've described there don't seem to be any other symptoms of this causing a problem, but as soon as we add and use a local user account the issue goes away.  So make sure all cached, project and installation resources are on the local system.
    James
    May 19, 2011 8:29 AM   in reply to mr_norris
    Unfortunately, PrPro has never performed well in a networked environment. Especially in corporate and academic situations, networking is commonplace. I would strongly suggest filing a Feature Request for more networking support. As it appears that you have documented the issue for you, I would share all of those data with Adobe.
    Good luck, and thanks for reporting your workaround.
    Hunt
    Jun 7, 2012 6:51 AM   in reply to MedInv
    Jun 7, 2012 8:02 AM   in reply to nazaartanoli
    Welcome to the forum.
    Please read here:
    Adobe Forums: "could not find any capable video play modules" error with HP Pavillon DV7
    If you have more questions about this issue, please start your own discussion.  This discussion is about a different error.  Thanks.
    Jeff
    Jun 7, 2012 8:30 AM   in reply to Jeff Bellune
    Thanks.. i will check that and come back you
    Jun 7, 2012 9:22 AM   in reply to nazaartanoli
    Thanks for the help.
