I am using
Windows XP-SP3 on my computer. I deleted flashplayer last week and now I get an message of need Flashplayer 9 for this brower back in 06 time frame. Where can I get a copy of flashplayer 9 and once I get it how can I load it to my computer? Thanks for all your help. Gerry
Hello,
Welcome to Adobe Forums,
You can download Flash Player 9 from here : http://fpdownload.macromedia.com/get/flashplayer/installers/archive/fp9_archive.zip
Note : You need to run Windows Flash Player 9 Installer from this Zip file.
Vikram
Note that deleting Flash Player 10 will not let you install an earlier version; you need to uninstall it.
I removed flashplayer from my computer while on the list of programs that I was looking at under add/delete in control file. I now have have two files for flashplayer when I do a search. These two files are flashplayer install.exe and flashplayer 7_winax.exe. I still get this message each time I click on an e mail-your brower must have flash 9 or higher installed to add this application. I have clicked on flashplayer install and get flashplayer installed, but where is it. It does not show up on the list of programs I have on my computer. When I down load Flashplayer 10 not a thing happens. How do I get a current program of flashplayer on my computer??? Thanks Gerry
Hello,
Download these Flash Player 10.3 installer on your computer :
http://fpdownload.macromedia.com/get/flashplayer/current/install_flash_player_ax.exe
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player.exe
Note : Make sure while installing Flash Player no application are running
Vikram
Thanks for all your help. I now do not get the message that my brower needs flashplayer to work. Flashplayer is now loaded on the list when I click on control panel and it also shows up when I click on add/remove programs under control panel. Thanks for your help. Gerry
