How can I make a SplashScreen with Flash CS5.5 or just with AIR/AS3 codes. I need it while the App/Game is loading...
I know that it's possible with Flex 4.5 as:
http://workflowflash.com/98437/air-for-android-splash-screen-with-flex-4-5.php
But I want to do it without Flex. So can I ?
Thank you
Android officially not support any splash screens, you make the one within your flash file with the preloader.
Use Default.png to show it as a splash screen.
The Default.png is for Iphone not Android, I need SplashScreen for Android apps.
nobody know about it ? ...
Can you give me some more info about this? How do you make a splash screen for android?
SO: You can't create a real splashSCreen or loader, you need to create a fictive loader/splashScreen at start of your apps.
Here is a workaround of both of you, Joeboy and SriDragon.
A sample to create a splash screen before your application begins.
As I said, you can't create a real splashScreen or loader, you need to create a fictive loader/splashScreen at start of your apps.Because a real Spash Screen like you can do with Android SDK, it display before loading your apps, so you don't have a 1 or 2 or 3.... sec black screen... (When you make a big game).
i'm not sure if this is necessary anymore, but i took the advise of another user here
http://forums.adobe.com/thread/764981
the key difference is, the user stated a preloading swf needed to embed the image in order to display before the whole apk is loaded.
Seems to be working for me anyway
Thank you
