WebHelp Pro TOC Missing Topics
May 20, 2011 12:25 PM
We are trying to publish Web Help Pro (RH8 and RH Server 8 (Apache Tomcat version 6)).  What we have just figured out through a lot of troubleshooting, is that the WebHelp Pro TOC doesn't display all the topics and in some cases reorders the TOC based on the defined TOC.  There is no issue until we reach the 194th Item (doesn't matter if it's topic, PDF, PowerPoint, or Book with no link).  The magic number is 194.  When the 194th item is entered in the TOC then books and topics disappear.  In some cases, an entire book of topics is moved under another book.
Does anyone have any clue as to what the issue is?  I've never had a limit to the number of items displaying in the TOC and this is a realtively small project of 295 topics (not including baggage files).
CJ
    May 20, 2011 1:51 PM   in reply to MeWrite
    Hi. I don't have an answer, but I have seen similar behavior, though I hadn't noticed the magic 194th item
    I know this is a small site, but is this part of a merged project system?
    Also, are you using the default "Server-side" search indexing or "Client-side" indexing?
    Finally, it would be helpful if you zipped up your Tomcat server log files for the past day or two that this problem showed up. You will find them here on the server machine:
    C:\Program Files (x86)\Apache Software Foundation\Tomcat 6.0\logs
    Send the zip to my email shown in my Forum Profile.
    I will reach out to someone at Adobe and see if they can help with this.
    John Daigle
    Adobe Certified RoboHelp and Captivate Instructor
    Evergreen, Colorado
    www.showmethedemo.com
    May 20, 2011 1:56 PM   in reply to MeWrite
    And I don't know how to help either, but I have to admit I was a bit stymied by your mention of the following:
    MeWrite wrote:
    ...and in some cases reorders the TOC based on the defined TOC...
    Shouldn't a TOC be presented as it has been defined? How else would you expect it to be presented?
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7, 8 or 9 within the day!
    Adobe Certified RoboHelp HTML Training
    SorcerStone Blog
    RoboHelp eBooks
    May 25, 2011 2:47 AM   in reply to MeWrite
    Hi CJ,
    There is a KB article which discusses the missing TOC issue for RoboHelp Server 8 and 9 and also gives the solutions for that issue. Here is a link to the article :
    http://kb2.adobe.com/cps/904/cpsid_90498.html
    Tulika.
    Jun 9, 2011 3:40 PM   in reply to tuls.garg
    We have this problem also. I tried downloading the fix from the knowledgebase and am getting the following error:
    The XML page cannot be displayed
    Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
    An invalid character was found inside an entity reference. Error processing resource 'http://kb2.adobe.com/cps/904/cpsid_90...
        <ul class="clsTOCHidden">&#32<xsl:for-each select="ETN"><xsl:call-template name="fnBuildToc"/><...
    Can you help, please?
    Dee
  • RoboColum(n)
    Oct 8, 2004
    Jun 10, 2011 1:32 AM   in reply to d2will
    Hi Dee. I have informed the relevant people at Adobe about this link. I'll post back once the link in working again.
      The RoboColum(n)   @robocolumn   Colum McAndrew
  • RoboColum(n)
    Oct 8, 2004
    Jun 10, 2011 1:56 AM   in reply to RoboColum(n)
    Adobe are fixing the link but in the meantime you can still download the file. Just right click on it and click Save Link as in Firefox or Save Target as in Internet Explorer.
    Jun 16, 2011 3:35 PM   in reply to RoboColum(n)
    Hi Colum,
    I tried to save the target. I get and XML file instead of a XSL. I went through the process in the KB article, but we still have the problem. Any other ideas?
    Dee
    Nov 4, 2011 5:28 PM   in reply to MeWrite
    Hello,
    Did you ever find a real solution to this (I mean, not just flattening the TOC structure to side-step the problem?) I'm having the same issues in WebHelp Pro output.
    Mike
