ADE does not recognize my Sony Reader
May 13, 2011 May 13, 2011
ADE help says it will automatically recognize my reader if I have it connected when I launch ADE.  It doesn't.  Suggestions?
5.4K
Engaged ,
May 14, 2011 May 14, 2011
First, please understand that ADE WILL recognize your SONY reader when it's
set up properly, plugged in and active at the time that ADE is launched.
So, if it isn't doing so, here are a couple of things to consider:
SONY readers come with installation software that will set up the reader,
help you set up an account at the SONY Reader Store and get it authorized,
and also specify your choices for how you wish to handle ebooks (you get a
choice whether to have the Reader Store or 'something else' - ADE - handle
.epub and .ascm files). You should choose to have your ebooks handled by
ADE.
ADE expects the SONY reader to be activated by the SONY store in order for
it to be able to do transfers, etc.
My guess is that you haven't set up the SONY reader yet....
May 19, 2011 May 19, 2011
OK...I didn't have my reader set up so now I've done that.  I didn't come across a place where it let me pick how I wanted to handle my files.  When I plug in my reader ADE still doesn't recognize.  I don't see an area to do this within my Reader Store account.  I haven't been able to read a book from the library yet.
Participant ,
May 20, 2011 May 20, 2011
Hi ,
In order to fix the problem you can try following.
Solution 1)    1) Connect the Reader to your computer.
                    2) There you will find a new drive created similar to C or D drive under My computer.
                    3) Open the Readers Drive and you will find a folder with name adobe.digital.editions.
                    4) Delete this folder and plug off and re plug in the Reader.
                    5) Open Digital Editions and it should ask you to authorize.
Solution 2) Modify the manifest.xml file located in C:\Usres\Username\My Documents\My Digital Editions:
1) Quit Digital Editions
2) Make a backup copy of the manifest.xml (call it something like manifest.good)
3) Open manifest.xml in notepad
4) It will appears as one big long line of xml, and you are looking for a tag called  start at the begginning of this
    and select until you the end of the tag that looks called </de:deviceID>
5) If you have attached more than one Reader there may be multiple of these.  Delete all of them to make sure.
6) Save the file (manifest.xml) and quit out of notepad
7) Ensure you have the Reader plugged in
8) Launch Digital Editions
9) The Device Setup Assitant should come up.
  a) Do NOT click on the "Don't ask again for this device" checkbox.
  b) Do click on the "Authorize Device" button.
I hope this will help you !!!
Regards
Rizwan
Engaged ,
If you try Solution 1 on a Windows PC, perform only the first action in Step
4. Then, eject your reader. Don't unplug it until the system reports it's
safe to do so. After you unplug the Reader, wait about ten seconds to make
sure that Windows knows the device has been unplugged, and then plug it back
in again. If you're not careful, Windows will screw up its linkage to the
Reader.
Guest
Jun 22, 2011 Jun 22, 2011
I tried all this and still does not work. We have two different Readers at home, and the program does not recognize either of them. Both worked fine just a week ago. Any other suggestion?
