Workspace Save As Draft feature
Jan 27, 2009 5:42 PM
Workspace allows you to save a form as a draft. What happens to draft
documents that are accummulated, but never acted upon, due to
circumstances like the user is no longer using workspace, or has left
the company, etc? I mean, I know that once the form is submitted and the workflow is activated, you can set expirations and escalations. But what if the person initiates a form, and saves it as draft, thereby NEVER submitting it to the workflow process?
Considering what I've been learning, I think that I must create a custom render service that first sets expiration dates and then render the form and then workspace-enables the form?
Please advise,
Elaine
    Jan 28, 2009 6:26 AM   in reply to Elaine Schmitz
    These "saved as draft" tasks will stay in the system.
    You could clear them up using the adminui, under Process Management.
    Jasmin
    Jan 28, 2009 7:29 AM   in reply to Elaine Schmitz
    So you click on your process under Process Management and you don't see it in there?
    If you go under Task Search, do you see it in there?
    Jasmin
    May 23, 2011 11:02 AM   in reply to Elaine Schmitz
    Here I go reviving a dead thread (yay zombies!) but I've run into this same topic recently, and wanted to share what I learned.
    Saving a form as Draft within Workspace results in a write to the database.  That's mostly obvious, it has to be persisted somewhere.  The problem is exactly WHERE in the database, and WHAT can you do about "old" drafts.
    WHERE is the Task table, tb_tasks, and the Form Data table, tb_form_data.  You can find all of the draft forms in your system with a query like this:
    SELECT TT.instructions, TT.task_description, TT.step_name, TT.service_title, TF.initformvariable, TP.canonicalname, TP.commonname, TT.start_time, TT.process_instance_id
    FROM tb_task TT, tb_form_data TF, edcprincipalentity TP, tb_assignment TA, tb_queue TQ
    where TT.id = TF.task_id AND TT.status in (2, 4) and TT.current_assignment_id = TA.id and TQ.workflow_principal_id = TP.id AND TQ.id = TA.queue_id
    Note that digging around like this is not recommended at all!  At least this is just a query, not a DB change, but there's no guarantees that indices are properly used and running this query won't consume your resources!
    The draft form is in the TF.initformvariable.  The rest are there to be informative to the reader.  The TF.initformvariable column equates to a LiveCycle Document data type.  You can't really hand edit it or anything.
    WHAT you can really do with this is, unfortunately, not much directly.  The good news is that as a Task item, old drafts should I believe get cleaned up using the Adobe Purge Utility, or the Avoka Purge Utility for a bit of a plug.
    Jeff Yates
    www.avoka.com
Bookmarked By (1)
