guide to connect Adobe drive with Alfresco CE
May 25, 2011 6:25 AM
Hallo everybody!
Since adobe remove version cue, i search for a replacement. Can somebody please write a short  guide how to configurate Alfresco CE to optimal work with adobe drive? Its drive me creasy, bljad! I think, i am not alone with this problem. Feel free to write here everethink, you found about it. Together we find a solution, i think.
The interest were (after connect Adobe drive to Alfresco CE):
- how configurate the space, where Alfresco CE saving the files ?
- how to set permissions to Alfresco CE drive to chek in the files from adobe programms?
- in bridge i cannot see the thumbnails of files (only the standart thumbs, maby it has something to do with the permission rights?)
- how can thomebody else from anywhere connect to Alfresco Cmis that is locally on my pc, like earler in versioncue, to callobarate)
Thanks to everybody for suggestions and help!
Adobe drive 2.1
Alfresco CE 3.4
    May 30, 2011 4:05 AM   in reply to Borisbritva
    Hi Borisbritva,
    To work with Adobe Drive, you just need to install and launch Alfresco CE server. No special configuration.
    Section 'Using the CMIS Connector' in CMIS CONNECTOR FOR ADOBE DRIVE 2.1: TECHNICAL NOTE doc shows the detailed steps on how to connect Alfresco server with Adobe Drive 2.1.  Below is the link for the tech note:
    http://help.adobe.com/en_US/creativesuite/cs/adobedrive/CMIS_Connector _Tech_Note.pdf
    For "how configurate the space, where Alfresco CE saving the files ?" & "how to set permissions to Alfresco CE drive to chek in the files from adobe programms?", I think you need to read Alfresco Document ( http://www.alfresco.com/resources/documentation/ ). For simply try, use admin account to connect Alfresco Server with Adobe Drive. CMIS CONNECTOR FOR ADOBE DRIVE 2.1: TECHNICAL NOTE doc gives the detail info about how to browse, check in, and check out files.
    For "in bridge i cannot see the thumbnails of files (only the standart thumbs, maby it has something to do with the permission rights?)",  Adobe Drive 2.1 with CMIS connector doesn't support it. But Adobe Drive has exposed API to retrieve thumbnails of files. If you have interest, you can download Adobe Drive SDK ( http://www.adobe.com/devnet/adobedrive/eula_21.html ) and try it.
    For "how can thomebody else from anywhere connect to Alfresco Cmis that is locally on my pc, like earler in versioncue, to callobarate)", Adobe Drive 2.1 with CMIS connector support it. Just replace 'localhost' with you external IP address in Server URL when connect to Alfresco server.
    Hui
