How to select only objects within a selection marquee?
May 24, 2011 8:40 AM
I am a new user of Illustrator CS5, switching from Freehand. I am trying to find out if there is a way to select only the objects within a selection marquee? In AutoCAD you can make a selection window from left to right and only those objects entirely within the window are selected. If you window from right to left all objects that are "crossed" or touched by the window are selected. Is there a similar technique in Illustrator?
Currently I have to select the objects, then go back and hold the shift key to deselect the object I don't want, or lock layers to prevent extra objects getting selected.
Replies 1 2 3 Previous Next
    May 24, 2011 10:46 AM   in reply to Ngaio9
    Try the lasso tool
    Works better than a marque as you are not limited to only square shapes.
    May 24, 2011 11:00 AM   in reply to Ngaio9
    It simply makes selections.
    May 24, 2011 11:17 AM   in reply to Ngaio9
    Ngaio9 wrote:
    I'm new to Illustrator, what does the lasso tool do?
    It doesn't do what you want that would be a good option if there were a way of invoking it with a keyboard toggle.
    Th lasso tool does pretty much what one would expect it to do it selects any object or path that falls within the area you outline with the tool on the canvas so if the object is only partially in the area it will be selected.
    It would be nice to have a toggle to select only objects that fall completely within the selection area or perhaps even something more sophisticated like settings for that fall within the selected area but only on the current layer or of  certain color fill as well,etc.
    Only way to do what you want is to use the layer panel and that can be a bit blind sided. At least that I know of and of course an entirely different process than you desire.
    I think this would be a helpful feature but zI would like it as a toggle rather than a change.
    May 24, 2011 11:23 AM   in reply to Ngaio9
    Say you want to select just the pink dots and not the blue ones, just drag round them like this with the lasso tool and they'll be selected on mouseup.
    May 24, 2011 2:55 PM   in reply to Ngaio9
    Ain't no picture there. Use the camera thingummy in the reply window to send pictures.
    May 24, 2011 6:59 PM   in reply to steve fairbairn
    Marie wants to be able to do this, where the dotted line is your lasso selection.
    I think the Lasso Tool would be a better place to put the feature rather than the direct select or the selection tool
    as you can define a more random selection. and what would be great is if you could access the lasso tool when using
    another tool with command l for the traditional way of selecting and option L for the way marie would also be able to select.
    I bet if she visited the scripting forum she might get those guys on it and a script might work.Problem there is keyboard short cuts for scripts do not stick
    so you might have to create an action invoking the script and assign keyboard to the action.
    It is a very good feature and should be implemented.
    May 25, 2011 12:32 AM   in reply to Wade_Zimmerman
    Hi Wade, I scripted it the way Marie originally wanted it, by defining a "window".
    I have made a coupe of tutorials on how to run scripts via 2-clicks and shortcut key stroke for Windose. They don't involve programming, so I wonder if there are similar features on the Mac that could do something similar. Hover the mouse over my username to check those out.
    #target Illustrator
    //  script.name = selectWithinRect.jsx;
    //  script.description = selects all items fully enclosed by a top most Rectangle;
    //  script.required = draw the "selection Marquee" Rectangle first before running;
    //  script.parent = carlos canto // 5/25/11;
    //  script.elegant = false;
    var idoc = app.activeDocument;
    var topPath = idoc.pathItems[0];
    var tpVB = topPath.visibleBounds;
    var left = tpVB[0];
    var top = tpVB[1];
    var right = tpVB[2];
    var bottom = tpVB[3];
    for (i = 1 ; i<idoc.pageItems.length; i++)
              var iart = idoc.pageItems[i];
              if (isPointIn(top,left,bottom,right,iart) == "true")
                        iart.selected = true;
              //alert(isPointIn(top,left,bottom,right,iart));
    topPath.remove();
    function isPointIn(top,left,bottom,right,iart)
              var vb = iart.visibleBounds;
              ileft = vb[0];
              itop = vb[1];
              iright = vb[2];
              ibottom = vb[3];
              if ( ileft>left && itop<top && iright<right && ibottom>bottom)
                   return "true";
              else
                   return "false";
    May 25, 2011 3:17 AM   in reply to CarlosCanto
    @Carlos: you need Third Party Software on the Mac, but then it's possible. I guess that QuickKeys would work, Spark does as well: http://www.cultofmac.com/cult-of-mac-favorite-spark-mac-os-x-utility/1 0153
    The scripts need to reside in ExtendScript's trusted folder.
    May 25, 2011 10:12 AM   in reply to Monika Gause
    Hi Monika, there it is then, good option.
    I've never touched a Mac but I've seen a bar at the bottom with shortcuts? in it.Can you put a shortcut to the trusted scripts folders in there? and if you can, does it act like a menu (like in windows) listing the files in that folder? or it will merely open the folder?
    May 25, 2011 10:29 AM   in reply to Ngaio9
    hahaha good analogy, for starters, does the script do what you wanted to do? based  on the screen shot
    May 25, 2011 11:06 AM   in reply to Ngaio9
    ok,
    - copy the script from previous post
    - open Adobe ExtendScript Toolkit
    - paste the copied script
    - save the script with a meaningful name
    to run double click on the script.
    if you want to run it from within Illustrator -> File -> Scripts Menu
    - save the script here:
    C:\Program Files\Adobe\Adobe Illustrator CS5\Presets\en_US\Scripts\
    - restart Illustrator
    folder path is for Windows...I guess mac would be similar path
    May 25, 2011 11:35 AM   in reply to CarlosCanto
    @Carlos: you mean the "Dock"? You can put links to any folder there. Just drag the trusted folder into the dock and there it is.
    May 25, 2011 11:59 AM   in reply to Ngaio9
    What is a script? - the text below the screen shot, in post 11. It is a sequence of commands Illustrator reads and excutes accordingly.
    What and where is the Adobe ExtendScript Toolkit - a program to create/edit scripts. It comes with Illustrator, it should be in the adobe folder neighborhood.
    Save what with a meaningful name. - the script
    Doubleclick where and on what? - on the saved script
    Does this then create a button or keystroke command in Illustrator? - it adds a menu item in Illustrator under, File->Scripts menu
    Does it change the actual marquee? - no, you draw the "marque" with the Rectangle Tool
    May 25, 2011 12:03 PM   in reply to Monika Gause
    got it Monika, thanks, good to know.
    May 25, 2011 12:51 PM   in reply to Ngaio9
    great!!!!
    May 25, 2011 1:58 PM   in reply to Ngaio9
    I've been waiting for this feature since around 1988 or so. In my experience, every application that has a selection lasso or box works in such a way that only the items completely inside the "fence" are selected. This is the way Claris CAD, Freehand, Canvas, VectorWorks, etc. have worked and always worked. Illustrator is the only application I've ever come across where objects are selected, counter-intuitively, by everything the "fence" touches. I chuckle when I see how hard it is to explain the "inside only" concept to those who have only used AI. It's like trying to explain the wheel to people who have been dragging things around all their lives. I've been asking for it on the feature request for as long as there have been feature requests, to no avail. I used Canvas for around 10 years before coming back to AI and I was shocked that the lasso still had the crazy, backwards select-all-it-touches system. Yes, you are correct. It should work the way you expect, capturing only what is completely inside the lasso, but it doesn't. I'm up to CS4 and I think it still doesn't, not even as an option. It is just about the strangest thing in software, but there you go. So many people have used AI and nothing else that they don't notice the backwardness of it and, in fact, get used to it. It just goes to show how adaptable humans are! Other than that, it's a fine application.
    MGuilfoile
    May 25, 2011 2:11 PM   in reply to Michael Brown12
    Michael we'll keep waiting another decade, in the meantime, the script does the job.
    May 25, 2011 2:15 PM   in reply to Ngaio9
    Marie, we've made some progress if it shows in the Illustrator scripts menu, were you able to get it to work?
    Monika/Wade, can you test if it works on a Mac please?
    May 25, 2011 2:33 PM   in reply to CarlosCanto
    Works fine on my Mac (OSX 10.5.8, AICS4)
    May 25, 2011 2:39 PM   in reply to Ngaio9
    With your file open, draw a rectangle which encloses some objects entirely and cuts across others. With that object still highlighted, File>Scripts>(whatever you called the script). It should delete the object you drew and highlight only those objects entirely within the area of the object.
    May 25, 2011 2:46 PM   in reply to Larry G. Schneider
    cool, thanks Larry
    Marie, maybe the problem is in what you actually saved,
    you should have copied starting here
    #target Illustrator
    then all the way down to
                   return "true";
              else
                   return "false";
    nothing else, is that what you copied?
    Message was edited by: CarlosCanto
    May 25, 2011 2:52 PM   in reply to Michael Brown12
    Michael Brown12 wrote:
    I've been waiting for this feature since around 1988 or so....
    You want too much.
    I simply want to be able to add and subtract from selection dragging the black arrow but it is not possible because it toggles the selection. I wonder who needs to toggle more than add or subtract.
    May 25, 2011 3:06 PM   in reply to emil emil
    hahaha, it's only been what? 23 years of waiting....
    May 28, 2011 6:42 AM   in reply to Ngaio9
    FreeHand (sensibly) provides a tool-specific option for contact-sensitve selection. Double-click the selection tool and choose whether it selects objects merely touched, or only objects fully-enclosed.
    Just one tiny part of the general tedium of Illustrator's selection/manipulation interface. Basic stuff that all competing programs do better.
    JET
    May 28, 2011 10:14 PM   in reply to JETalmage
    JET
    I would be opposed t this approach I would rather have a toggle I think preference is fine for a default setting but not as the only way of accessing your preference a toggle is better and I think the current behavior in AI is fine as the default. And to go further the use of the toggle and the setting of the default should be user defined.
    that is the toggle should be on by default but the user can turn it off if for some reason.
    This is one of the reasons I think the approach like other applications as a reason onto itself is misguide, who cares what other applications do or do not do as part of their mechanism. As long as a feature or an enhancement  or improvement of a feature is well thought out then that is al that counts.
    As far as I can tell most users that use Illustrator use by choice by a vast majority changing the functions of Illustrator to match other programs that Illustrator user have rejected doesn't make much sense.
    I started out with FreeHand and didn't like it I own a license to Corel's Suite for the Mac and did not like it, besides the fact that it constantly crashed.
    I chose Illustrator because I got my work done, it worked for me.
    I think the what is rudimental in other programs should be of no concern of Illustrator uses.
    The new clipping mask behavior was ill conceived there should be a choice of how one wants the clipping mask feature work. And the same here it would be a very thoughtless act to dump one behavior for another with out thinking of the options and the needs of the vast majority of users.
    I writing this here just in case someone from Adobe thinks this is a much requested feature, which it is not, but just in case they should think twice about suggesting the change.
    May 28, 2011 10:16 PM   in reply to Wade_Zimmerman
    Also also to add it to the lasso tool would make it much more useful then to just the selection tool which is confined to a rectangle selection.
    May 29, 2011 5:44 AM   in reply to Wade_Zimmerman
    The Contact Sensitive setting in FH is "a toggle" (a checkbox, to be exact). It is not a general preference setting. If you really had even a working familiarity with FH, you'd know that.
    You need to loose your over-sensitive adversion to any mention of FH. Adobe now OWNS FreeHand. Therefore, it does not have to worry about any copyright infringement when copying interface features from FH.
    And I have never said that every FH advantage (of which there are many) should necessarily be implemented exactly as it is in FH. The functionality is what's needed. But even when trying to do that, the results fall short because Illustrator is continually hindered by its stubborn adherance to more basic inferior interface schemes upon which the new functionality is dependent. Examples include the inferior (and decades-late) implementations of aligning anchorPoints, cutting multiple anchorPoints, and extension/retraction of handles.
    JET
    May 29, 2011 8:47 AM   in reply to JETalmage
    Try this again.
    You miss the point.
    I would elaborate but do not see the point of that.
    Good luck with your quest to bring FH back from the grave.
1 2 3 Previous Next
Actions
